Old 10-21-2017, 12:41 AM   #1
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
Isc 8.3 vs dt466e
Hello,
Im am still in search of a bus. While i would prefer a mechanical fuel injection I'm mostly finding newer electric engines. Any opinions on isc 8.3 vs dt466e for power, reliability, longevity? I have read that the pre 2003 isc had the CAPS fuel injection prior to common rail and that they had issues. Dt466e ran a HEUI but havn't read anything bad about them. Any other pros or cons to these engines?
Thanks
Ted
Old 10-21-2017, 10:51 AM   #2
Great question.
Both engines have very good reputations. I look forward to hearing from the DT contingent.
Old 10-21-2017, 11:17 AM   #3
alot depends on what bus body style you want.. the 8.3 is most common in a rear engine.. the 466E seems to show up most in front engine busses, though it exists in rear engine as well..
Old 10-21-2017, 12:17 PM   #4
TJones's Avatar
Chassis: CS RE
The only 8.3 I have seen are in RE. I was set on getting a conventional but after some research i might be leaning toward a RE.
Old 10-21-2017, 12:24 PM   #5
Bluebird did equip All American FE's with the 8.3.
Not sure I would want to turn wrenches on one though.... I like the access that an RE provides.
Old 10-21-2017, 03:44 PM   #6
Chassis: International FE
Rated Cap: 84 passengers
When I started looking for a bus I really only wanted something with a DT466 in it. It's just a great engine. Very smooth running, pretty good fuel efficiency, easy to work on. For me, the biggest benefit is how long it has been made. Parts are literally everywhere for it. The only downfall to the 466E is how expensive new fuel injectors can cost for the HEUI system.
rensch26 is offline   Reply With Quote
Old 10-21-2017, 09:48 PM   #7
TJones's Avatar
Chassis: CS RE
The HPOP could be expensive to replace as well. I should look up pricing on 466 fuel system parts vs isc 8.3 as well as the pricing of in frame kits.
Old 10-22-2017, 06:03 AM   #8
I almost won a BBAA FE with a mechanical 8.3 in it.
The only configuration I haven't seen and would buy in a heartbeat would be a SHORTY with 8.3!
Roll Your Own Build Thread
Old 10-22-2017, 10:40 AM   #9
I could get REALLY excited about a shorty with a 6 speed manual and an 8.3!!!
Old 10-22-2017, 01:05 PM   #10
There could be some out there, but I've not seen one.
Maybe someone should get a nice older bus and swap those in!
