Old 10-14-2015, 10:35 AM   #21
Chassis: Blue Bird
Engine: ISC 8.3
Thanks for the tip about the mechanical priming lever on the B engines. It's one more reason why I find working on Cummins engines so pleasant (compared to other engines): they're designed to make servicing easy. I'll have to look for a similar feature on my other engines.
I had a second look at the lift pump operation on my ISB this morning. You're right, it does energize the lift pump at key-on -- but it's on for only about half a second on my pickup ('98.5 Dodge with an '01 engine computer, I think). If I bump the starter I hear the lift pump come on again and it runs about 30 seconds. It could be different with the vocational ECM used in buses..?
Old 10-14-2015, 12:22 PM   #22
Engine: 3208 turbo Cat
Hey Guys, this is good information, I have been afraid to replace the fuel filters on my 1984 BB CAT 3208, is it the same general Idea? can anybody here write something like Family wagon and Nat did? for a Cat engine.
J
juliol is offline   Reply With Quote
Old 10-14-2015, 12:25 PM   #23
opus's Avatar
Chassis: All-American R/E
3208 is the same. Pull the filter, fill it with fuel, put it on and fire it up. No need to do anything else. There should be a twist lock type hand primer as well, should you ever need it.
Old 10-15-2015, 02:15 AM   #24
Hey thanks again all of you I think my bus has the electronic engine you speak if because when I turn the key but let off the ignition too soon she acts likes she's flooded and then won't start for like 10 minutes does that make sense to u?
Sunbear is offline   Reply With Quote
Old 10-15-2015, 06:58 AM   #25
okay my advice to add
I got very tired after pumping the stupid priming pump a million times so I-->
My fuel tank cap is solid and not vented, so this told me that I had a vent hose on the tank it's self
Using a tire pump I put the attachment to fill up air mattresses on the end and inserted into the vent hose, I pressurized tank to 8/10 pounds (do not go crazy with it and dont go higher it will do no good except spray everwhere)
I then cracked the lines at the filter and then at each injector and she fired right up
when done unscrew cap to let pressure out, be careful of spray if tank is full
Old 10-15-2015, 10:16 AM   #26
Chassis: Blue Bird
Engine: ISC 8.3
That's clever, bansil. Good idea.
Old 10-15-2015, 12:25 PM   #27
Bansil, did you do this after changing fuel filters? also did you fill the new filter with diesel? .
Old 10-15-2015, 02:22 PM   #28
yes there are a few pics in my build,
it started with clogged fuel filters and turned into this after accidentally moving a wire
it was a week long craptastic involving a bad fuse, broken wire, extra solinoid and very sore thumbs from everything sitting for a week, all lines drained
http://www.skoolie.net/forums/f11/la...a-7581-33.html
Starts bottom of page 33 and ends on page 35
at least I learned from my adventure
Old 10-15-2015, 02:58 PM   #29
Bansil what year motor does LA tortuga have is it the same motor as mine? 97 5.9
Old 10-15-2015, 03:10 PM   #30
it is the basic 5.9 12 valve, it should be the same.
I think ours is 97 also, it used to say under my avatar...mmm
Old 10-15-2015, 06:55 PM   #31
Engine: 190hp 5.9 Cummins
Bansil's engine is a 12 valve fully mechanical engine.
Yours in a 24 valve electronic engine.
So no, you and Bansil don't have the same engine.
Always fill fuel filters before installing.
Failure to fill the filter will lead to a ton of work and frustration.
Old 10-16-2015, 06:45 AM   #32
How do we know he has a newer 24valve?
Did I miss something?
Old 10-16-2015, 12:44 PM   #33
So nat your saying as long as I fill my filters with diesel when I turn the key forward one click it should prime itself and fire up (hopefully)
Old 10-16-2015, 02:12 PM   #34
Unless the filter is filled you would be pumping that volume of air through the system. Not good and a PITA to bleed. Even filling it you will get a little air but nothing like what a dry filter would yield.
Old 10-16-2015, 08:04 PM   #35
Nat I'm on e should I get gas and then change the filters or vice versa?
Old 10-16-2015, 08:21 PM   #36
You could do the oil change a hour after shutting down and it ill still be plenty hot.
Old 10-16-2015, 08:47 PM   #37
Chassis: Blue Bird
Engine: ISC 8.3
If we may agree to disagree on the importance of pre-filling the fuel filter...
It's been a while, but I don't recall pre-filling for my 24-valve ISB engine. Just let the electric lift pump fill it; the air is pushed past the injection pump and returns to the fuel tank.
Can't pre-fill the filter on that Deutz engine I referred to earlier: knucklehead design has its fuel filter inverted above the oil filter (grumble, grumble!). Just changed this one last week; I was actually surprised at how quickly the engine ran again after the filter change with only one of its three injector tubes loosened to bleed the air.
Sunbear, it's not clear whether you have the 12-valve B or the 24-valve ISB engine. Do as nat_ster suggested earlier and look at the valve cover; if it is the 24-valve it'll say so in letters about 1.5 inches tall. Being model year 1997 I'm anticipating it'll be 12-valve.
In the 24-valve case you can pre-fill or not, and can let the electric pump finish the fill. If you can be near the engine and listen carefully when the key is turned on, the pump is quiet but audible. If it runs a while that's great. If it runs just a few seconds or less, try bumping the starter to test whether that makes it run longer. With pre-fill I'd probably look for 20 seconds of lift pump; without pre-fill maybe a minute of pumping before actually trying to start the engine.
In the 12-valve case there isn't an electric lift pump and I agree with the others that pre-filling the filter would make the manual priming easier.
Doesn't matter whether the fuel tank is nearly empty so long as there's enough fuel in there to spill some on the floor, re-fill the filter, and run the engine long enough to get to the fuel station before the tank runs dry!
Old 10-17-2015, 08:16 AM   #38
since there seems to be a cloud over what engine he has
do you have 6 valve covers like 12v
or 1 valve cover like 24v
because "thinking" it's electronic doesnt mean much
that is easiest way
Old 10-17-2015, 09:18 AM   #39
Roger the above. There is a big difference in the priming and "starting drill" between electric & mechanical lift pumps.
Old 10-17-2015, 09:27 AM   #40
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
that is easiest way
I think I would like to have one of those two engines in my Excursion instead of the 7.3.
I'm hungry!
You Gotta Let Me Fly
