Old 01-15-2018, 07:24 PM   #21
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Originally Posted by Jolly Roger bus 223 View Post
You don't always get charged batteries from an parts store.
That's why they have a battery charger on hand if you have them replace the battery.
They don't say that if you just exchange and walk out with one/three.
Next time you tell them you want the ones in the back not the ones on the front shelf and you want to see the standing charge in them before you buy them.
Should be at least 13 at a minimum or it barely has a chance. Especially if it's not the same replacement. I have two 8d's and one in mild temps does it just fine but in colder temps I do believe both have to play the game.
Yeah I know about them not being charged off the shelf
Hmm 13volts huh? I always understood it as 12.60
Doe69936 is offline   Reply With Quote
Old 01-18-2018, 10:59 AM   #22
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
So it’s been too cold to work on the bus but I’ll update when I can get back to work
Old 01-18-2018, 05:02 PM   #23
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
So it was a bad ground from battery to frame thank you every one
