Old 03-21-2017, 07:22 PM   #21
scan gauge is another options. I like mine
Old 03-22-2017, 08:36 AM   #22
MasterMerck's Avatar
Engine: 5.9L Cummins
Decided to go this route. Will let you know after I get them installed. Maybe some pictures.
Universal Triple Gauge Console Dash Pod with Dome Lip
MaxTow 1500°F Pyrometer
Black & Green MaxTow 30 PSI Fuel Pressure Gauge
Black & Green MaxTow Transmission Temperature
MasterMerck is offline   Reply With Quote
Old 03-22-2017, 08:41 AM   #23
cool lookin gauges!!
the max PSI of your lift pump is less than 30 PSI?
the one on my 444E is 72..
Old 03-22-2017, 08:47 AM   #24
turf's Avatar
lol, anyone notice the cheapo plastic clock taped onto the gauges?
Turfmobile Build Thread
Old 03-22-2017, 08:49 AM   #25
LOL. I didn't see that originally!
From what I have read the Cummins pumps will not be over 20 max psi on fuel.
Nick
Old 03-22-2017, 08:56 AM   #26
NO I musta been blinded by the bad-assness.
Old 03-22-2017, 10:39 AM   #27
I have one other issue. My fuel gauge shows incorrectly.
Tank filled = 2/3 on the gauge.
40 gallons left (60 gal tank) = 1/3 on the gauge.
Does that sound like a sending unit issue? Other issue? Anybody ever replace one? Do I have to drop the whole tank?
Nick
Old 03-24-2017, 04:40 PM   #28
turf's Avatar
i think i've heard others say the same thing. i know my fuel gauge reads wrong to the advantage of the driver.
i have a 60 gallon tank and the needle is on empty when there is 20 gallons left.
Old 03-24-2017, 09:09 PM   #29
I've been a pilot for 30 years and I have never flown a plane with that many gauges! Just too much $hit to keep up with.
Old 03-25-2017, 11:55 AM   #30
Oh, cool! I have my license as well, although I haven't flown since 9/11. (You don't want to know what kind of hoops you have to jump through to fly the airspace around here, let alone base your plane inside the TCA.) I think gauges are still easier than the fly-by-wire flat screens that the world has gone to now. That's a subject for a different thread, though.
Old 03-27-2017, 11:26 AM   #31
Chassis: International 1753
Engine: 6.9 International
Exactly why most fleets are going to the bare basics. Just too much $hit to keep up with that most drivers forget to pay attention to the main thing, and that's the road.
Booyah45828 is online now   Reply With Quote
Old 04-05-2017, 08:21 AM   #32
Brewerbob's Avatar
Christ the money I've spent with them on the RX-7/8 build!! I could have bought 4 buses and had money left over.
All of my gauges work. The fuel, oil pressure, oil temp, and coolant (???) are all on a single multi function gauge. It also has the typical car range of L and H. That, while it works, has got to go!!
I want individual decidated gauges. I'll end up with something like the pics you posted. Because of my advanced years, I prefer analog gauges so it'll look like some off the Wright brothers' airplane. I used a dual analog from an aircraft supplier in the FrankeinB (RX-7/.
Old 04-05-2017, 08:24 AM   #33
Brewerbob's Avatar
Originally Posted by MasterMerck View Post
I do have:
"Fuel, MPH, RPM, Water temp, Oil Pressure, & Voltage"
That is all on a switch on the dash. Multi-gauge kind of setup.
Yeah, that. Only my speedo is separate. Don't like it.
Old 04-05-2017, 08:31 AM   #34
Brewerbob's Avatar
No but that is likely to be the first "upgrade". I need to open a new bank account to get the free clock with the double sided sticky tape. Do they even give those away any more?
Old 04-05-2017, 08:35 AM   #35
Brewerbob's Avatar
Nick
That sounds normal to me and came with a warning from the school guy. "Don't believe the fuel gauge until you get use to them." I have a 60 and with a hair less than a 1/4 left, I put in 37 gallons. I dunno where the rest of the gas is.
My Dakota gauge went nuts on me and left me on the side of the road once. 3/4 on the needle and the tank empty. I figured the ex had put $20 in it and didn't reset the trip meter. I'll never believe ANY fuel gauge again. I use MPG and odometer.
Old 04-05-2017, 08:37 AM   #36
my "clock" was first my cell phone holder on the windshield.. my current Clock is a time stamp across the top of the 10" center screen that displays all my gauges in real numbers...
analog face gauges look cool... but really when depoending on how you turn your head your oil P can " vary" by 10.. yeah I like reading a number that says 43 PSI.. rather than well maybe its 33 or maybe its 53..
Old 04-05-2017, 09:42 AM   #37
Here is an old racers' trick...
Clock all of your gauges so that all of the needles point straight up when the readings are "normal". All it takes is one quick glance to see if anything is out of bounds.
At 200 mph you don't want to have your eyes off the track for long.
Old 04-05-2017, 10:00 AM   #38
Brewerbob's Avatar
Nice trick but that sounds like a fancy bunch of gauges. Or are you talking about just rotating teh body os that 0 is at 5 o'clock instead of 7 or 8 where it would normally be.
Old 04-05-2017, 10:12 AM   #39
turf's Avatar
200mph in a bus would be awesome!!!!!
Old 04-05-2017, 11:03 AM   #40
Robin97396's Avatar
To go that fast I think you'd best go with one of those airplane fusilages attached to the bus to reduce wind resistance. Maybe some wings too in case you get airborn.
Robin
Nobody's Business
