Old 10-11-2019, 08:49 PM   #1
MT 545 speed
I'm looking at a 2001 freightliner with a Thomas body. It has the 24 valve 5.9L cummins with a MT545. First I know that the 643 is better in many ways and often preferred. I'm not looking for that debate. I also understand that rear gears and tire size will affect speed ( dont know what the rear gear ratio is but the tires are 10R22.5) my question is what kind of speed can I expect? My dad just purchased the same bus but a year newer with the 643 and on the was home from indiana he was pushing 75mph on flat ground.
Getaway_bus is offline   Reply With Quote
Old 10-11-2019, 09:36 PM   #2
Without knowing your gear ratio no one will know what speed your bus can go except you if you floor it on a long road.
Year of bus makes no difference nor does horsepower. Its ALL gearing. You could have a bus that tops out at like 45 if its from a district that has 45 mph buses. I had one from Cleveland Texas that was limited to 50 in the ECU. That's another thing- it could be electronically limited even if it has highway gearing.
Too many variables make more of guess than "somewhere between 45 and 85".
Roll Your Own Build Thread
Old 10-11-2019, 10:18 PM   #3
The 545 is an AT(auto/truck), the 643 is an MT(medium duty truck).
Old 10-15-2019, 09:06 AM   #4
If I can adjust the electronic governor on the engine, how well can the 545 handle 70-75 mph?
Old 10-15-2019, 09:10 AM   #5
Its not the best for highway use. Mine is new and tight so it does fine. Watch your temps. You'll know when to slow down if you do.
A beefy cooler will help.
Your rear gearing is by far the main factor in your cruising speed and rpm's.
mt545
