Old 03-14-2019, 05:02 PM   #1
NH 220 oil pan
How hard is it change an oil pan gasket on a cummins NH 220? It is a horizontal engine that is a 1968 crown bus.
Robert Clint is offline   Reply With Quote
Old 07-04-2019, 08:14 PM   #2
You still need the info on changing the gasket or ya already did it?
HOGCAT is offline   Reply With Quote
Old 07-05-2019, 07:36 AM   #3
You will have to remove the starter, oil filter, air compressor and alternator to make room to remove the oil pan after you drain the oil. The pan is cast aluminum so its not that heavy after all the bolts are removed.
