Old 09-27-2014, 10:53 AM   #11
Chassis: International 1753
Engine: 6.9 International
Re: Get the alternator check first
Originally Posted by frank-id
The voltage from an alternator only must exceed the battery voltage. There is a problem with the alternator or some wiring is not good. Crown buses use a relay which operates the starter solenoid. Use a multimeter and check for poor connections. A fully charged battery is 12.6 volts and a battery 75% discharged will show 12 volts. Frank
You're correct, But certain alternators have very poor low rpm performance. Thus they don't produce, or produce very little power at idle (It seems that most high output alternators are like that for some reason). In these instances you won't see 14 volts with the engine idling.
Verify that the gauge is reading correctly and we will go from there.
Old 10-09-2014, 11:42 AM   #12
Year: 1972
Coachwork: Homemade
Chassis: Crown Supercoach
Engine: Cummins NHH 220, E-F10spd
Re: NHH 220 pancake in Crown coach questions
Ok, I've got a situation. The previous owner covered the engine hatch with ply and flooring, and I would have to tear everything up to get to the hatch. Is it worth the hassle to make the hatch useable? Will I ever need to get at the top of the engine? there isn't much on top of this motor, I have noticed some configurations have a starter and other bits on top of the engine but mine has nothing but the side of the engine casting facing skyward.
Good, Fast, Cheap - Pick any two
Vanopolis is offline   Reply With Quote
Old 10-09-2014, 12:43 PM   #13
r_w
You will need access if you don't have it. If you cut open the hatch now, you will never need it. --Murphy
r_w is offline   Reply With Quote
Old 11-06-2014, 01:53 AM   #14
Year: 1972
Coachwork: Homemade
I can't find a primer for the fuel system, it's got a PT fuel pump (mechanical everything) I have a new filter and would like to slap it in there.
Also leaking some fuel around an injector, 3 nuts and a spring all stacked up on the injector and didn't want to tighten it up unless that was the right choice.....?
When I come to a stop once in a while the engine idle drops to 400rpms and tries to die, if I blip the throttle it recovers. Could this be caused by the fuel leaking and or old fuel filter?
Taking her to the shop tomorrow for an alternator test, then to Betts truck shop here in PDX for shocks, bushings, bearings and leafspring repair.
Old 11-10-2014, 08:35 AM   #15
There might not be a primer pump on there. If there isn't, find a way to plug the center hole of the fuel filter and fill it full using a jug. Make sure you plug the center hole because that is where the filtered fuel comes out of. Then swap the filters, start it up, and run it at high idle. As for the injector leaking, take a picture of what you're talking about because the injector Is under the valve cover, so I don't think that is what you are seeing. The engine idle could be because of the leak. Does it seem to misfire when it does it? or is it just low idle? Either way, we need to fix the leak first and then trouble shoot from there.
Old 11-10-2014, 01:47 PM   #16
Year: 1972
Coachwork: Homemade
It seems to idle fine at startup, 500rpms. Then after a bit of driving the idle is just too low to keep running without some throttle finesse.
The bus is at the shop for a week to have the broken leafspring repaired, new shocks/bushings, bearings and seals. I'll try to dig up a photo of the "injector" I'm looking at, It's where the fuel line goes into the head.
The new fuel filter made it run better and greatly improved throttle response.
Old 11-10-2014, 07:06 PM   #17
go00nascar's Avatar
Engine: 5.9 Cmmins
Rated Cap: 71
as for the low rpm. with engine temp above 140 deg. F you can adjust idle by removing plug out of rear of fuel pump housing the fuel will run out . take a small screwdriver and turn screw 2 clicks or about 1/8 turn .re-install plug start let run for a few minutes.check idle rpm's should be 550 rpm .if after setting idle if still tries to stall you can adjust throttle leakage. engine must be at 170 deg f or higher. this can be done by loosing the nut at throttle shaft the one at rear of shaft. start engine turn screw till rpm starts to rise no more than 25 rpm. tighten screw.
go00nascar is offline   Reply With Quote
Old 11-11-2014, 12:54 AM   #18
Year: 1972
Coachwork: Homemade
Excellent! Thanks for the procedure on the idle adjustment, I found the "cone" your talking about on the fuel pump and it's nice to know how far to turn that screw.
The screen filter with the slotted top in the top of the fuel pump will not come out, I got a big flat head in there with a wrench on it. Not sure if I could have put more force into it without doing damage, any ideas on getting at that filter?
Old 11-11-2014, 01:39 AM   #19
Year: 1972
Coachwork: Homemade
Old 11-11-2014, 06:21 PM   #20
go00nascar's Avatar
Engine: 5.9 Cmmins
Rated Cap: 71
that was a problem with those pumps. corrosion easy to twist off screw. no easy cure don't heat it or o rings on throttle shaft will leak. not many people rebuild those pumps can be expensive. i would idle up a little an put up with drupe with the 10 speed you wont notice a few extra rpm s at idle or shifts
Who owns a Gillig or Crown with a pancake engine. crazycal Mechanical and Drivetrains 25 03-24-2017 05:12 PM
Three Crown Super Coach II's for sale Crown_Guy Classifieds | Buy, Sell, Swap 11 01-03-2015 01:30 AM
1990 Crown Super Coach II Locutus Classifieds | Buy, Sell, Swap 3 06-23-2010 01:44 PM
Crown Coach tools kyjohn Classifieds | Buy, Sell, Swap 2 12-15-2007 02:33 PM
1971 Crown Coach Conversion chakra Classifieds | Buy, Sell, Swap 1 05-06-2005 01:56 PM
