Old 07-20-2016, 12:52 PM   #131
It's tough work...but somebody's gotta' do it. Here's hoping the oil thing stays sane. Ride on.
Old 07-24-2016, 06:04 PM   #132
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
Not sure how your engine is set up, but we had a major oil leak that we thought was coming out of the blowby tube, but it turned out our oil pressure pipe to the turbo had been chafing against some lines and had a pinhole in it. To find it we cleaned all the wet oil off the engine (it was all over the exhaust and oil pan next to the tube) and then ran it in place for a good long while to find out where a drip would spring up.
I don't remember what kinda bus you have but if it's wet sleeve and you need a rebuild it's honestly not too hard to do yourself if you have tools.
My build thread:http://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
onenationundergoat is offline   Reply With Quote
Old 09-05-2016, 05:24 PM   #133
dredman's Avatar
well I figured dragging this thing across CO Rockies might finish her off, and it is starting to look like that might be the case. Once I get her started she runs like a top, and pulls like a schoolbus. Even crawled across Vail Pass this afternoon - runs like normal?
This only happens when she is cold, otherwise she bumps right off?
Anything I can do to get her down the road a few more months? (2500 miles)
How long till she does not start?
Would ether help?
Headed towards Grand Junction to ask a diesel guy
Skip to 4 minutes to avoid MOST of the pain
My 3 Year Adventure
dredman is offline   Reply With Quote
Old 09-05-2016, 05:50 PM   #134
im not sure how the cummins does it, as i dont think there are glow plugs. but hard starting at altitude can be a sign of failed glow plugs. fuel isn't preheated enough to combust.......
hope that helps
Turfmobile Build Thread
Old 09-05-2016, 06:28 PM   #135
2kool4skool's Avatar
hope that helps
They have a grid heater in the intake tract.
Don, Mary and Spooky the cat.
Old 09-05-2016, 07:44 PM   #136
dredman's Avatar
well it is good to know that it might be fixable. I have been high up (8,000+ feet) and it has been pretty chilly up here.
So would ether help start it?
Is there a way to check the heater?
My 3 Year Adventure
Old 09-05-2016, 08:21 PM   #137
Dred, Cummins says NO ether!
There's a intake heater icon on the dash. When you start the engine do you wait until all the pre-start ritual* is complete? That gives the heater time to do it's thing, that is: key to run...wait*, then to start.
Old 09-05-2016, 09:20 PM   #138
dredman's Avatar
yes I wait, I even wait on subsequent attempts, and even cycle without starting
My 3 Year Adventure
Old 09-05-2016, 09:25 PM   #139
Chassis: IH
Yeah, seems to me the preheater grid isn't doing its thing. Typically it's supposed to (1) turn switch to run (wait to start), (2) wait the few seconds for the heater to warm up, (3) turn starter. Ford 7.3's and others do much the same thing. My suggestion would be to see if the grid heater is getting voltage when it's cool. That'll help narrow it down.
Old 09-05-2016, 09:30 PM   #140
dredman's Avatar
Wonder why it had issues at noon tho? - Think it was close to 70 degrees?
My 3 Year Adventure
