Old 10-01-2016, 01:09 PM   #1
chad.nuesmeyer's Avatar
Engine: Cummins 5.9 (24v)
Rated Cap: 66 Passenger
Oil Change 5.9L - '01 tc2000
I just bought a bus, want to do an oil change... Curious what the Cummins groups thinks. How much oil, type,brand... and what filter does the group recommend?
Any hints or tips as I get ready to crawl under there?
I want to also swap out the transmission fluid. Any extra thoughts on how much or brand? Bus, has the Allison 2000 Series transmission.
chad.nuesmeyer is offline   Reply With Quote
Old 10-01-2016, 02:05 PM   #2
2kool4skool's Avatar
I use:
4g Supertech 15-40 for the engine, NAPA filters. Different trans.
Tips.. bring a large oil container.
Don, Mary and Spooky the cat.
Old 10-01-2016, 05:58 PM   #3
Chassis: IH
I typically use 15W40 oil for diesels, whatever is on sale. Wal-Mart store brand usually. FYI, diesel oil was reformulated in the last 4-5 years (and new engines were designed to use it; something to do with EGR and DEF and soot filters, I forget all the specifics now), make sure to get "the old stuff" (still widely available). Most of what you'll find in the big box stores will be exactly what you need.
Old 10-01-2016, 07:05 PM   #4
For your vintage stay away from LE oils.
Old 10-01-2016, 07:11 PM   #5
Chassis: IH
Yes, that. LE = (Low Emissions?)
Old 10-01-2016, 09:53 PM   #6
I use Rotella T 15-40 in my DT-360, and I'll be using it in my T-444E as well.
Old 10-03-2016, 07:25 PM   #7
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I'm getting ready to change mine for the first time, I'm going Amsoil 15-40 with Donaldson filters
Old 10-03-2016, 07:40 PM   #8
Year: 1994
Its actually cheaper to buy new engines than to run that expensive oil. Imagine you get 250K on the engine divide that by your oil changes and times it by the cost. Oil is like talking to people about religion for some reason. Best price on oil is chevron and it meets the military spec plus its in the walmart brand. Then at $2 a quart its worth changing as often as you like. My dt466 takes 30 quarts a in chassis overhaul is worth about $3000.00. I rather by a motor than oil.
Geo Jeff is offline   Reply With Quote
Old 10-03-2016, 08:00 PM   #9
Chassis: Genesis
If you are spending money to get Amsoil, by far the best oil, you might as well go for one of these: Spinner IIŽ Products : High-efficiency lube oil filtration for heavy-duty diesel engines.
I have a Dieselcraft OC-25 which is a similar thing, but Dieselcraft doesn't seem to like to sell them anymore? Not sure what is going on with them. Either way, the amount of soot it removes from diesel oil is impressive in my experience.
On the other hand, be warned that if you have 'tired seals' on a bus, Amsoil will clean every bit of nasty out of every crack on them. I had a /very/ worn engine that I thought I would use Amsoil on. Oh it cleaned everything up real nice... and then it burned oil like crazy from then on.
This should have been expected, but I wasn't thinking when I did it. Ah well. Amsoil is what I plan on using as well with regular oil tests and the centrifugal bypass oil filter taking care of the little particulates.
</ramble>
Timelord is offline   Reply With Quote
Old 10-03-2016, 08:06 PM   #10
</ramble>
I'll have to look into that a little closer, I was planning on the Amsoil dual filter by pass kit.
