Old 08-07-2016, 06:35 PM   #1
Oil leaking from Radiator fan motor
So I have this oil leaking from my radiator fan motor right where it meets the blades. Nor sure if it's caused by to much pressure or a bad seal. I drove the bus about 2500 miles to get it home. It did great and cruised. I did however need to stop need refill about 1qt of oil to reservoir for the cooling system every couple hundred miles.
Thanks in advance for any advice.
Ben
Ben Alth is offline   Reply With Quote
Old 08-08-2016, 12:06 AM   #2
Year: 90
Chassis: international
I'm hoping you misquoted yourself. You added oil to the cooling system? you just opened a giant can of worms. Water goes in the cooling system, not oil.
We need more details on this fan motor. Are you talking about the hydraulic motor that drives the fan on an R E bus?
Old 08-08-2016, 12:27 AM   #3
Rated Cap: 37,400 lbs GVWR
You have a hydraulic fan motor? Yes, they can leak either internally (like mine was) or externally (like it sounds yours is). What make of motor do you have? Maybe a seal kit is available, providing that the bores inside are not worn and that the gears still mesh tightly?
I have a Webster YC fan motor - seal kits for YCs are on eBay, but only for the pumps, not the motors that use higher-pressure seals. QCC is the current maker of YC pumps and motors, so I had them make me another exact replacement to go with my new Multi-Wing fan. My motor was simply not turning fast enough due to internal leakage, contributing to my bus's chronic overheating issues.
Old 08-08-2016, 06:00 AM   #4
Yeah, hydraulic fan motor is leaking oil out towards the fan and the fan is the shooting all over the engine compartment. I will clean it off today and see how the fan is spinning.
Will it be easier to just replace the hydraulic motor apposed to fixing seals in it?
Old 08-08-2016, 07:22 AM   #5
Chassis: IH
I assume you topped off the hydraulic system, and *NOT* the coolant using oil?
Old 08-08-2016, 07:29 AM   #6
Yes, assumption is correct
