Old 07-15-2018, 11:35 PM   #1
Chassis: MVP ER
Oil Pressure Issues
I have this problem with my oil pressure gauge reading about 95 psi at idle and 98 when loaded. Someone on here sometime ago said that most likely it is the oil pressure sending unit. So I decided to get it changed before I hit the road this Friday.
Where will I find that switch? I have a 1999, 5.9 Cummins rear eng., with 24 valves. I have found the fuel filter, external trans filter, and shame on me, I don't remember seeing the oil filter. It was late so I get back under there tomorrow.
Anyway the parts guy said that it should have 3 wires coming off of it. But where is located. Thanks.
budbud7 is offline   Reply With Quote
Old 07-16-2018, 12:39 AM   #2
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
Don't some oil pressure gauges show the maximum when their wires are shorted? It could be as simple as a short somewhere, maybe?
Old 07-16-2018, 01:29 AM   #3
Chassis: IH
I've had a failed oil pressure sensor cause the gauge to show excessively high readings.
More than once, if memory serves me correctly.
Old 07-16-2018, 09:19 AM   #4
Chassis: International 1753
Engine: 6.9 International
Should be on the left side of the engine(passenger side if it is an RE bus)
