Originally Posted by BennysTire
Typically 120 to 130 is the max on the tires I fill. But if the compressor is at 130 (or even 150) the last 20psi takes forever to fill, as the pressures are nearly equal. I usually run 180.
As far as CFM, around 30. 1" gun is thirsty, and I am usually airing up tires while changing another...
Oh, I don't think they will miss those last 20 psi in the tires...They have 90 already.
180 psi?
If we had run that in the cabinet shop I used to work, the guys would be giving themselves embolisms weekly. I bet you have a healthy respect for machinery and stored energy.
