Old 01-30-2018, 10:28 AM   #21
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by BennysTire View Post
Typically 120 to 130 is the max on the tires I fill. But if the compressor is at 130 (or even 150) the last 20psi takes forever to fill, as the pressures are nearly equal. I usually run 180.
As far as CFM, around 30. 1" gun is thirsty, and I am usually airing up tires while changing another...
Oh, I don't think they will miss those last 20 psi in the tires...They have 90 already.
180 psi? If we had run that in the cabinet shop I used to work, the guys would be giving themselves embolisms weekly. I bet you have a healthy respect for machinery and stored energy.
Old 01-30-2018, 11:26 AM   #22
Chassis: B3800 Short bus
Cool. A world I wasn't even aware of! Did a quick search and found these crazy compressors:
VMAC Air VR150
Engine mounted
150cfm
175psi.
Holy crap..
Old 01-30-2018, 11:59 AM   #23
BennysTire's Avatar
Chassis: TC-1000
Engine: 5.9 Cummins 24v
Rated Cap: 39 Students
VMAC Air VR150
Engine mounted
150cfm
175psi.
Holy crap..
I had a VMAC. Terribly expensive to purchase AND maintain. And the air is SO wet!
Sent from my E6883 using Tapatalk
BennysTire is offline   Reply With Quote
