Old 03-05-2007, 05:30 PM   #21
the_experience03's Avatar
You guys are hardcore. I can only think of a few times that I have had to do stuff like that. You know...using a screwdriver for the mains fuse on the truck, vise gripping brakelines shut, adjusting EFI resistance values with a gum wrapper to get the truck out of limp home mode, replacing birfield joints on the trailside. Nothing quite like that. I probably never would have figured out the solenoid to be perfectly honest.
And Elliott....I feel your pain. My bus to the college got stopped for 15 minutes one day by a semi with a full 53 ft refer that had to turn into an alley off of the main road here in Duluth. The poor guy got it eventually, but man...talk about high stress.
This summer I will be parallel parking my bus on the street out in front of my apartment. I'm not looking forward to that.
Old 03-05-2007, 06:02 PM   #22
Elliot Naess's Avatar
Engine: 5,9 Cummins
No pain. Just good sport. One time, I had a bunch of pedestrians applaud me for popping
the rig into a "hole-in-the-wall" dock in one smooth movement. They were local folks
and used to being held up for a long time there. Just comes with practice. (And... It ain't
braggin' if'n it's the truth! -Will Rogers)
Now let me tell you about the time the clutch....
Old 03-05-2007, 08:07 PM   #23
some of the 5.9's with the VE pump use a solinoid with an internal plunger scrwed into the pump body, it is spring loaded in the off position and energized to run, if the engine won't start/run, remove the solinoid, take out the plunger and spring, install the solinoid housing and the engine will run. to stop the engine you have to manually pull the kill lever on the side of the pump.(not connected to the solinoid.
« - | Got to go faster. »
Trim Coil rube2112 Conversion General Discussions 7 08-03-2014 04:07 PM
Best way to pull up rubber mat? TygerCub Conversion General Discussions 6 10-15-2009 06:35 PM
Pull behind solar trailer Lady Franklin Conversion General Discussions 1 01-15-2009 08:26 PM
A good place to pull 12v from? Train-train Conversion General Discussions 3 11-12-2007 11:58 PM
Need toad stuff to pull my s10 behind skoolie JonCBrand Conversion General Discussions 9 09-14-2006 01:37 AM
