Old 07-28-2017, 09:15 AM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Radiator cap
Cannot find a new radiator cap for my 93 carpenter. It leaks and I'm overheating every 30 miles.
Sent from my LGLS676 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 07-28-2017, 09:39 AM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Did you try a truck stop? It is probably not the same as an automobile sized cap.
Old 07-28-2017, 09:40 AM   #3
Coachwork: myself
Chassis: amtran
No. I'm at napa and they are baffled. I'm going there next.
Old 07-28-2017, 09:46 AM   #4
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
What motor? The motor dealer may have it also.
Old 07-28-2017, 09:47 AM   #5
Coachwork: myself
Chassis: amtran
Cummins. That's a good idea but we are in the middle of nowhere. Chilicothe ohio
Old 07-28-2017, 09:50 AM   #6
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Truck stop may be your saving grace. I am sure I have seen a wall of stuff like radiator caps. The diameter is probably different than on a car. Look at the cap and get the right psi... If there is a limited selection and you have a choice of a lower pressure, and a higher pressure.. go higher and try to find the correct one down the road.
Old 07-28-2017, 09:51 AM   #7
Coachwork: myself
Chassis: amtran
Thanks I'll look. The trick stop is close
Old 07-28-2017, 09:52 AM   #8
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Good. If you have to limp to a Cummins dealer, call ahead and see if they have it first. Then take it slow and have plenty of coolant with you.
