Old 07-15-2017, 01:26 PM   #1
Year: 1972
Engine: Cummins NH220
Radiator for a Cummins 220
Hi All,
I am restoring a 1972 Crown with a rusty radiator (engine: Cummins 220).
I had the radiator boiled but the core is dead so it is unfixable. I am now looking for a replacement radiator (making a new one is $2000+).
Does anyone have an advice on where to find the part? School depots? Scrap Yards?
Thank you in advance!
hanaiapa is offline   Reply With Quote
Old 07-15-2017, 01:47 PM   #2
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Originally Posted by hanaiapa View Post
Hi All,
Where did you get it boiled out at??
Old 07-15-2017, 02:36 PM   #3
Year: 1972
In Riverside, Fontana Radiator. They're supposed to be pretty good.
Old 07-15-2017, 03:01 PM   #4
I think you are s.o.l.
Due in large part to the shape I doubt you will find another radiator that is used that will fit.
$2K doesn't sound too bad.
The paperwork the church got with their Crown has a receipt for a new radiator that cost $3,500.00.
Old 07-15-2017, 06:58 PM   #5
To bad it's not up here I would recommend calling Star Radiator in Woodland & talk with them.
Old 07-15-2017, 07:20 PM   #6
seems abolut that time I would be making another type of radiator work...
I admit i know zero about crowns but seems making some bracketry and such and universal hoses that an aftermarket radiator of some type could be fabbed in.. there are so many shapes and sizes of radiators for about every application made.. and most of themn are under $1000 new OEM and aftermarket stuff thats less than $500.. even a primary and a remote to gain the amount of cooling reqiired..
Old 07-15-2017, 11:46 PM   #7
Engine: TE 444
Rated Cap: 12
Your best bet would be to get the dimensions of your radiator and call some big truck junkyards to see if they have anything close in size, also measure where it goes in the bus to see if something slightly different in size will fit
Old 07-16-2017, 05:16 AM   #8
yeah. truck wrecking yard... n fab up whatever mounts u need
Old 07-16-2017, 09:10 AM   #9
The basic problem for those who own Crown or Gillig mid-mount engines is that nothing else uses radiators of those dimensions. They are significantly wider than most truck radiators and less than half as tall. They are also significantly thicker than most radiators as well.
It isn't helped by the fact that all of the Crowns that have been crushed have been crushed in a way that no usable parts are able to be harvested from them. The engine and transmission have to have holes drilled into them before everything is crushed.
I would like to know how we are saving the environment by crushing perfectly usable equipment.
Old 07-16-2017, 09:23 AM   #10
I can't believe the prices posted. As long as the upper and lower tanks are remotely usable it should not be that big a deal. I have had several custom rads built from scratch here in Houston for about $300 bucks(?).
