Old 07-24-2017, 03:56 PM   #1
Chassis: Tc20000000
Engine: 5.9 cummins
Rated Cap: 30,000
RE vs FE differential compatibility
I have a 95 TC 2000 Fe. I found a similar bus same rearend but it is a rear engine can I just flip the diff 3rd over ( rotate 180°) and put it in my front engine rearend or will my bus now drive backwards... Or should I just keep searching for a third member from a front engine... thanks .
Godzilla is offline   Reply With Quote
Old 07-26-2017, 07:19 AM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
I may be mistaken... The re is in line with the rear just reversed.. so the "front of the engine" is facing the back. The engine and transmission rotate the same direction... If they are the same then they will be a direct swap, no flipping necessary.
Old 07-27-2017, 05:25 AM   #3
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Originally Posted by Godzilla View Post
...or will my bus now drive backwards...
Yes, unfortunately you will have to get good at using your mirrors going backwards down the highway.
differential goes both ways- bus goes both forward and reverse.
Gears are cut to work better/quieter in one direction, however. Proper lubrication is also a consideration.
more info
So, yes, it would work...for awhile. How long is anyone's guess.
Old 07-27-2017, 07:25 AM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Think about that. In a rear engine the engine is "pulling" you backwards. Only has one speed that direction. Turn the whole drive train around, the engine is "pulling" you frontwards, only has one speed.
Old 07-27-2017, 07:27 AM   #5
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Now I am lost. Lol
Old 07-27-2017, 09:36 AM   #6
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
A few years ago someone here changed the diff on his RE bus to get higher gearing. He got a complete axle from a truck and turned it upside down (i.e. he did not just rotate it horizontally so the old right side was then on the left), and he had to drill new oil fill and drain holes in the casing. If you rotate the axle horizontally, you'll have one forward and several reverse gears!
diff swap
