07-15-2017, 01:37 PM
Engine: Cummins 5,9 12V
Rated Cap: 24 seats, 3 wheelchairs
Recalibrate speedometer?
The previous owner of my '98 BB TC2000 upgraded to highway gears, so the speedo is about 15mph off. How do I fix it?
07-15-2017, 04:40 PM
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I would imagine that your local dealer could do it. It's not a DIY project.
07-15-2017, 04:56 PM
i don't know if thats mechanical or not, but the mechanical transmissions have a speedometer gear by rear end.
i have seen a list of different part numbers on a '92 BB partlist for the speedogear.
here is picture of a page from an online catalog.
if you have an electronic motor, i have no clue.
hope that helps
07-15-2017, 05:00 PM
easy way to tell is crawn underneath and at the rear of the transmission tailshaft (on a 545 its usually on the driver side).. see if there is a pair of wires coming off or a cable coming off (not the shifter)..
if its a cable then you have a gear.. if all you need to change is the DRIVEN gear and not the drive gear then its super easy... that cable pops out and you swap a new gear in..
if you have an electronic speedometer then there is any number of ways that it might need set..
for example my 1991 bus is a fully mechanical engine but I have an electric speedometer.. in that case there are dip switches on the speedometer cluster that you set.. (I did it when I changed tire size).. im not sure on a bluebird how its done. just throwing out ideas..
07-15-2017, 05:09 PM
Thanks! I'm familiar with the dip switches as my van has that. Couldn't find one on the bus so that's what prompted the question. I'll take a peak under the bus when we stop for wires and such.
hope that helps
Thanks!!
07-20-2017, 02:18 PM
Ok - so a couple details that might be helpful. The rear axle ratio is 4.78, which I am told by the previous owner is the newer gears he put in.
I finally got around to crawling under there. So this must be the speedometer sensor and there's a wire coming out of the top. So does that mean I need to find some dip switches somewhere?
07-20-2017, 03:02 PM
i'm curious about the speed sensor too.
my at545 has 2 wires that come off in the same spot as the picture above.
my at1545 has 2 wires that come off next to the gear selector.
in either case, those 2 wires have to carry a neutral start switch, a reverse light indicator and a speed signal.
the only other electrical connection is the ground strap on the transmission.
someone start splainin'
curious that the old owner would put in a 4.78. that would take you from probably 58mph to 65mph.
mines a 4.78 and i'd go for a 4.3 or 4.1
07-20-2017, 03:56 PM
I suspect my RPMs are lower. Iowa to Ohio I stayed around 60mph and my RPMs were 2k. Tracking via GPS I got just over 12mpg. Bus weighed ~18,500 on that trip. On a flat run I can get just over 70mph tops.
So, how does all of that compare to someone with stock gears? ¯\_(ツ)_/¯
07-20-2017, 04:18 PM
thats real good!
i have the same set up
5.9, at545, 4.78 rear. i'm 19k lbs
top speed of about 72
i get 7.5mpg
07-20-2017, 04:35 PM
thats real good!
i get 7.5mpg
So - was your 4.78 an add-on and your speedo is off too?&
07-20-2017, 05:02 PM
all factory
i keep my foot on the floor and push it all day long.
07-20-2017, 05:48 PM
I'm wondering if these circle doohikies on the back of the dash cluster are dip switches.
Also the dang dash bulbs are touchy. :/
07-20-2017, 05:51 PM
Chassis: Blue Bird
Engine: ISC 8.3
To me those look like sockets for replaceable lamps.
07-20-2017, 06:05 PM
That's what another person said on FB. But there are separate lamp spots like this... And they're stupid sensitive. Can't figure out why some aren't working.
07-20-2017, 08:29 PM
Ah - you're right. They are the bulbs for the fuel/temp/charge/oil menu that I can toggle through. Some of them must be out bc I can't see them well at night.
07-22-2017, 12:11 PM
It was pointed out in another forum that technically I'm not 15mph off. I'm a % off. So he run the math and I'm 133% off across all speeds.
07-22-2017, 01:50 PM
since its a Bluebird, it doesnt hurt to call a bluebirds dealer and just ask what it takes to recal the speedometer.. if its a hard coded thing and you need a new gauge, or if its a reprogrammable thing in the field or dealer.. I just noticed your gauge [anel itself was marked bluebird.. so its made by them and not a chassis builder.
07-22-2017, 09:10 PM
[emoji106] I'll probably do that this week. Thanks for the discussion!
