Old 05-26-2016, 05:29 PM   #11
Robin97396's Avatar
Don't be silly, who needs a photographic memory?
So it's a '97 TC2000, probably a 5.9 and 545. They seem to have difficulty with internet access. Starts and dies after fueling. Oregon isn't self-serve, unless you're on a reservation, so that decreases the chances of the mis-fuel unless it was a young new employee. Yeah, should say on the receipt if you got one.
Doesn't that sound like a bad electrical fuel shutoff valve? I've been wrong before.
Old 05-26-2016, 07:57 PM   #12
Probably a bad flux capacitor! need to get it up to 88 1/2mph and see if it takes him to the future.
dgorila1 is offline   Reply With Quote
Old 05-26-2016, 10:04 PM   #13
roach711's Avatar
Rated Cap: 19
I most definitely have a pornographic memory.
The Roach Motel
Old 05-27-2016, 03:15 AM   #14
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Me too!!! Me too!!!! Me too!!!!!
M1031A1 is offline   Reply With Quote
Old 05-27-2016, 05:07 AM   #15
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
This thread is useless without pictures!
...um...wait...
Dapplecreek is offline   Reply With Quote
Old 05-30-2016, 09:30 AM   #16
I had similar symptoms on my Dodge 3500 with a Cummins 5.9 and found that I had lost prime between the lift pump and the injector pump.
It baffled me because the lift pump was working and the injector pump was fine. It was the air trapped in the top of the injector pump and the tail end of the input line (coming from the lift pump).
When I removed the input line from the injector pump and turned on the ignition it flowed LOTS of fuel. Turn the ignition off, reattach the line and try to start. Nada....
What finally got me going: poured fuel into the top of the injector pump until full, loosely attached the input line to the injector pump. Turned the ignition on and watched fuel squirt all over for 20 seconds then tightened the fuel line. Truck started right up.
The whole process above played out over about 6 hours of tinkering.
Don't know if this helps... If not maybe someone else has thoughts?
If all else fails: Southern Oregon Diesel-Roseburg Oregon 97470 I have had work done by these folks in the past and would not hesitate to call them again. Good (bus) People.
Good luck & safe travels.
Steve
