Old 05-25-2016, 09:51 PM   #1
So im brokedown in medford with my 4 year old 600 miles from home
So I just filled the tank and pulled outside the truck stop ate lunch and started her up she idled and died . I removed the filter water separator and the mixture that came out of there seemed very watery so I replaced the filter primed it. And then removed the smaller fuel filter and dumped it and refilled it and cracked the line there and we know the fuel pump is pumping it doesnt seem to have air in the lines . Also when we crank her over it seems to puff white of thin smoke or steam out of the tailpipe .
Sunbear is offline   Reply With Quote
Old 05-25-2016, 10:03 PM   #2
Chassis: Genesis
White smoke is diesel not burning/burning right. Possibly a filter issue. Actual steam is all manner of bad.
Timelord is offline   Reply With Quote
Old 05-25-2016, 11:21 PM   #3
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
How about you start by telling us what you are driving? Mule, car, bus, spaceship? Is it a diesel? Are you ABSOLUTELY certain you filled with diesel and not gas? Do you have your receipt? It wouldn't be the first time that mistake has happened.
I'm hungry!
You Gotta Let Me Fly
Old 05-26-2016, 05:21 AM   #4
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
From an earlier post, it is a 97 bb tc2000.
Dapplecreek is offline   Reply With Quote
Old 05-26-2016, 05:47 AM   #5
what "medford" are you brokedown in? if its medford ohio im not far from there...
Old 05-26-2016, 06:18 AM   #6
what "medford" are you brokedown in? ...
Earlier post said, "I live in s.f." so this is likely Medford, Oregon, just above California, not too far inland.
Old 05-26-2016, 06:51 AM   #7
You go dapplecreek!
jake_blue is offline   Reply With Quote
Old 05-26-2016, 07:50 AM   #8
I like this crew...you guys are better than private detectives! You can track down anything in short notice! Love it!
dgorila1 is offline   Reply With Quote
Old 05-26-2016, 09:46 AM   #9
Moderator
crazycal's Avatar
I don't have a pornographic memory where I can remember everything someone wrote in another thread. If someone wants help, the least they could do is provide some basic information. I've never read his other posts and I'm not going to look for them.
I'm hungry!
Old 05-26-2016, 03:42 PM   #10
Chassis: International 1753
Engine: 6.9 International
Pornographic huh? or do you mean photographic?
I know which one I'd like to have.
Old 05-26-2016, 05:29 PM   #11
Robin97396's Avatar
Don't be silly, who needs a photographic memory?
So it's a '97 TC2000, probably a 5.9 and 545. They seem to have difficulty with internet access. Starts and dies after fueling. Oregon isn't self-serve, unless you're on a reservation, so that decreases the chances of the mis-fuel unless it was a young new employee. Yeah, should say on the receipt if you got one.
Doesn't that sound like a bad electrical fuel shutoff valve? I've been wrong before.
Old 05-26-2016, 07:57 PM   #12
Probably a bad flux capacitor! need to get it up to 88 1/2mph and see if it takes him to the future.
Old 05-26-2016, 10:04 PM   #13
roach711's Avatar
Rated Cap: 19
I most definitely have a pornographic memory.
The Roach Motel
Old 05-27-2016, 03:15 AM   #14
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Me too!!! Me too!!!! Me too!!!!!
M1031A1 is offline   Reply With Quote
Old 05-27-2016, 05:07 AM   #15
This thread is useless without pictures!
...um...wait...
Old 05-30-2016, 09:30 AM   #16
I had similar symptoms on my Dodge 3500 with a Cummins 5.9 and found that I had lost prime between the lift pump and the injector pump.
It baffled me because the lift pump was working and the injector pump was fine. It was the air trapped in the top of the injector pump and the tail end of the input line (coming from the lift pump).
When I removed the input line from the injector pump and turned on the ignition it flowed LOTS of fuel. Turn the ignition off, reattach the line and try to start. Nada....
What finally got me going: poured fuel into the top of the injector pump until full, loosely attached the input line to the injector pump. Turned the ignition on and watched fuel squirt all over for 20 seconds then tightened the fuel line. Truck started right up.
The whole process above played out over about 6 hours of tinkering.
Don't know if this helps... If not maybe someone else has thoughts?
If all else fails: Southern Oregon Diesel-Roseburg Oregon 97470 I have had work done by these folks in the past and would not hesitate to call them again. Good (bus) People.
Good luck & safe travels.
Steve
