Old 12-21-2017, 08:00 PM   #21
Rivetboy's Avatar
Here is the starter from my 91 5.9. To the right of the bolt and cable is a cover held on by 3 bolts that is where the solenoid plunger and the starter contacts are. You can buy these replacement parts very inexspensively. Also the ammeter is shunted so it does not have the full amperage going through it, just a calibrated percentage.
Rivetboy is offline   Reply With Quote
Old 12-22-2017, 09:27 AM   #22
Chassis: International 1753
Engine: 6.9 International
are our starters like that one picutred??? thats a GMC style starter with an integrated solenoid.. THAT type of solenoid moves the gear... if your solemnoid is external then no the solenoid doesnt movde the gear.. those are just a big switch and inertia moves the gear out to engage the fly wheel.
On the smaller cummins(3.9-5.9) engines they use a denso gear reduction style starter.
I linked the video to show how the bendix and one way clutch operates because it showed it well and I feel that is his problem.
Larger cummins (8.3+) engines will use a similar starter as the video, where the solenoid will help start gear engagement.
Old 12-22-2017, 01:58 PM   #23
turf's Avatar
Cummins's Quickserve gives the number as ST9068.
that doesnt really google a match but it has plenty of pictures.
napa lists some different ones for a 3500 94 dodge.
Turfmobile Build Thread
Old 12-22-2017, 02:02 PM   #24
On most Cummins there are usually several starter options. I know my 4BT shows three or four as well as both right and left side fitting. Can be tricky at times finding the right one as a direct replacement on some older engines.
Old 12-22-2017, 02:02 PM   #25
Chassis: Saf-T-Liner MVP ER
Someone upthread mentioned that maybe it wasn't "greased" properly.
Bendix gears run dry! Maybe a little graphite lubrication, but basically none at all.
If they get grease or oil on them, they can stick.
Steve Bracken
Build Thread
Old 12-22-2017, 11:58 PM   #26
turf's Avatar
well, it sounds like no matter what, its coming off.
i could have dinged it up the starter with the trans swap. i did grind one of my first steel spacers into dust. it could have been there. the edge of the flywheel that catches the starter gear is a bit rounded over.
tomorrow or sunday i'll start it and see how it goes. if its ssdd, the starter will come off, if all it needs a cleaning, it be worth the time. if its ssdd the second time i'll get a new one.
last weekend i tightened battery connections so maybe i'll have better luck as well
i did find the part number
3924410 which does translate in napa's online system
Old 12-23-2017, 12:11 AM   #27
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Skimmed the thread so not sure if mentioned, but did you shim the starter when you changed transmissions? If that's where it was mounted....I was JUST laying under my bus starter 10 minutes ago, didn't look.
Old 12-23-2017, 09:55 PM   #28
turf's Avatar
i got the bus started today and made my weekly maintenance loop.
here is a better description of of the starter noises.
it engages and the flywheel turns it a bit and then the starter flys off and winds up.
after an hour of trying, i got it started. i let it sit plenty, but i know i havent been kind to this starter in the past.
the ammeter was all over the place again. i suspect loose wiring.
as i rolled down the road, the bus made a horible dragging noise. i hit the flashers and pulled over. got out and looked under the bus for what ever had broken loose. nothing!
i got back in and started on my way again, and then it happened again, that clanky dragging noise. this time i realixed i was a glass bowl in the microwave ratlling around.
Old 12-23-2017, 11:30 PM   #29
too funny.. s glass bowl... yep that can definitely sound like metal parts coming into bits!!
so after you get your bus started can you shine a flashlight up into your inspection hole and make sure the flywheel is turning true.. if the flywheel is spinning untrue then at times the teeth would be close to the starter and at other times far away.. might explain for it coming off the wheel... although it almost sounds like the solenoid fails to hold once it is engaged.. looking at the pictures your starter looks like the type that has the solenoid driven gear as opposed to a standard bendix.. ive had those type solenoids go weak on me. (on GM vehicles).. the solenoid is a separately serviceable item..
Old 01-27-2018, 05:50 PM   #30
turf's Avatar
the starter gave it a few more ummphhs, and she help up until today.
i pulled out the starter and see the problem immediately. the starter gears have worn and no longer make contact on the flywheel.
i got a new one ordered and on the way.
