Old 09-23-2013, 01:00 PM   #1
Coachwork: Crown by Carpenter
Chassis: Ford B-800
Engine: 5.9L Cummins
Rated Cap: 55
Throttle adjustment?
I was told when I bought my Ford B-800 from the used truck dealer that a school bus usually has a modified system so it can only go up to about 60mph (or the throttle is otherwise limited). Going up a hill, it is SLOW, probably about 20mph at some times. The engine is a Cummins 5.9L.
Is there something perhaps to adjust with the throttle levers? Or something with the injection system? The dealer said something about "plates" that potentially block something. I really don't know much else.
Of course going any faster (speed or acceleration) is maybe a dumb idea when the vehicle fully loaded is around 10-12 tons.
tomas_maly is offline   Reply With Quote
Old 09-23-2013, 02:18 PM   #2
Re: Throttle adjustment?
Plenty of info about fuel plates etc on the Cummins forums
I don't know where you live, last night coming home I was in 1st gear at 2300 rpms going up the 8%+ grade (6 miles) into Boone this is normal for mine
these are big and heavy with "small" engines
I wont turn mine "up" until I replace the tranny with something stronger (your engine likes 2200/2500 rpms in our applications)
Old 09-23-2013, 02:28 PM   #3
crazycal's Avatar
If you turn up the power, make sure you install a pyrometer.
I'm hungry!
You Gotta Let Me Fly
GMC 351 V6 Throttle spring bansil GM | Chevrolet Drivetrain 0 05-22-2013 05:48 AM
throttle issue smitty500 GM | Chevrolet Drivetrain 3 04-02-2012 06:08 PM
Throttle conversion cschlessman Cummins Drivetrain 1 08-20-2010 02:15 PM
IP Adjustment for Altitude PAtoNM Conversion Tutorials and How-to's 3 08-15-2008 10:52 AM
Governor adjustment reprobate Conversion Tutorials and How-to's 6 12-29-2007 06:56 PM
