Old 09-13-2010, 02:18 PM   #1
Engine: 5.9 Cummings
Rated Cap: 24
Top RPM for a cummings 5.9 24 valve engine
I just bought my first bus 31 passenger, 1999 Bluebird flat nose. I what should my top highway rpm be. While driving it home 2100 rpm was all it did. I read a little about limiters etc. Can the rpm's be higher than that for highway speeds? The speedo said 52 mph but I think that may be off. I was going down the interstate and I think if I was going 52 mph a lot more people would've been passing me.
funbus63 is offline   Reply With Quote
Old 09-25-2010, 06:12 PM   #2
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
Re: Top RPM for a cummins 5.9 24 valve engine
A 24 valve Cummins 5.9 can see 3400 rpm. Can't say I would keep it that high, but it can do it.
nevrenufhp is offline   Reply With Quote
Old 11-22-2010, 11:02 AM   #3
Rated Cap: 24
Re: Top RPM for a cummings 5.9 24 valve engine
i called Cummins today about the speed issue. They said it probably has a " Max speed setting" in the ECM. You have to take the bus to a Cummins dealership to have them go into the "features and perimeters" of the ECM and increase the maximum speed which in turn will let the rpm's increase with the speed. they said it would cost between $170.00 and $345.00 depending if they have to erase any password locks that may be on the ECM.
Old 11-22-2010, 06:32 PM   #4
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
Originally Posted by jak
you can put a 3000RPM spring in the pump & it will do that all day
mine does 2500RPM all day now turned up a bit
JAK
The 24 valve is electronic, not a 6BT.
Old 12-19-2010, 07:19 PM   #5
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
i like to know what is the top rpm on a 5.9 12 valve 160 hp eng its in a 94 b/b,flat nose help......that 58 mph is for the birds ,lol would like 65 mph
keith is offline   Reply With Quote
Old 12-19-2010, 09:24 PM   #6
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
It could spin to 3200-3400 as it sits, but you sure wouldnt want to hold it up there for too long. Fuel economy drastically drops, and so does the engine's over all life. My advice: re-gear the rear end, or get an overdrive trans.
Rpm's on a Cummings Stu & Filo. T Conversion General Discussions 11 12-27-2013 12:46 PM
RPM's on a Cummings Stu & Filo. T Mechanical and Drivetrains 15 12-13-2013 12:16 PM
1992 Bluebird w/ Cummings engine runs on used tranny oil??? sdwarf36 Veggie Oil | WVO | Biodiesel | SVO 7 11-18-2012 04:04 PM
EGR valve? hoser Everything Else | General Skoolie Discussions 4 07-08-2010 07:38 PM
WTB - cummings diesel bus? mrbisset Classifieds | Buy, Sell, Swap 3 05-23-2006 11:25 PM
