Put the probes where you want. Sale Price:$375.00
12-Channel Digital EGT and/or CHT Pyrometer Gauge Display
Overview
• User can configure display as 2, 4, 6, 8, 10, or 12 channels
• 3-1/8" (80 mm) Round Gauge
• Recall Max temperature "Peak hold" capability
• Programmable High Temperature set-point alarm
• Each individual input channel can be labeled as either EGT or CHT
• °F/°C selectable
Features
• Compatible with any of our EGT probes & CHT sensors
• Accepts up to12 probes
• High resolution LCD display with backlighting
• Temperatures can be displayed in °C or °F; from -100 to +1200ºC (-148 to +2192°F)
• Display up to 12 channels in an easy to read bargraph format
• Visible high temperature alarm; LED changes to red color
• Recall Max Peak temperature memory Button
• Power from either 12 VDC or 24 VDC
• Supports J, K, & E thermocouple probes
The 12-channel digital thermocouple pyrometer gauge display is 3-1/8” instrument that contains all the features necessary to monitor EGTs and/or CHTs. The instrument is fully programmable by the user resulting in the most flexible solution available. The gauge display can be configured to display up to 12 thermocouples in an easy to read bargraph format.
