Old 03-08-2016, 04:47 PM   #1
2kool4skool's Avatar
U Joint Q
Opinions please. Is it creeping, leave it, replace it?
On our Blue Bird bus, front joint, joint is tight.
The other side of the same X:
Don, Mary and Spooky the cat.
Old 03-08-2016, 05:04 PM   #2
Skoolydoo's Avatar
Rated Cap: 2+1
Don it looks ok to me from a picture, I believe if you are in doubt in any way shape or form.
Just do it,replace it for pease of mind
Don and Ellen
Plus one fuzzy faced kid (Poopcee)
Skoolydoo is offline   Reply With Quote
Old 03-08-2016, 05:08 PM   #3
To my shadetree trained eye it looks like the bearing cap may be rotating?
Old 03-08-2016, 05:13 PM   #4
Coachwork: Honey Badger RV Co
Chassis: tc2000
Engine: 5.9 cummins
Rated Cap: 74
Buy a new u-joint strap kit with bolts. Make sure to get the torque correct.
wauto is offline   Reply With Quote
Old 03-08-2016, 05:57 PM   #5
opus's Avatar
Chassis: All-American R/E
To me, the bottom fastener on the bottom pic, looks loose.
Old 03-08-2016, 06:14 PM   #6
The cap has moved. It would be moving unless there was some force being exerted somehow. That cap should be spinning without much resistants. Change it, and the bolts and the straps.
DT Rutledge is offline   Reply With Quote
Old 03-08-2016, 06:15 PM   #7
Thanks all, here's the underside of the strap.
Finding this issue is a result of regular inspections, don't catch them all but I try....
Old 03-08-2016, 06:16 PM   #8
Looks deformed.
Old 03-08-2016, 08:38 PM   #9
Alan N's Avatar
Year: 1975
Chassis: Gillig
If you are in town, get the parts and fix it.
If you are not, grease it up and drive to town.
It needs fixed,but it should work for a while.
Alan N is offline   Reply With Quote
Old 03-08-2016, 08:42 PM   #10
opus's Avatar
For the price of the joint...and now that you have it apart.
