Old 08-04-2017, 10:35 PM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Valve job question
Exhaust side valve 1st. Cylinder.
After loosening the retaining screw i had a difficult time turning the adjusting screw. I turned quite a bit until it loosened up but couldnt set a gap. It looks like it is turned out too far.
I turned it over for a minute or two getting diesel to the injectors. It really sounded nice. But i didn't start it.
I didn't see much travel in the valve. If i start it and that cylinder doesn't exhaust what could happen ?
Sent from my LGLS676 using Tapatalk
Dead pirate is offline   Reply With Quote
Old 08-05-2017, 08:37 AM   #2
Coachwork: myself
Chassis: amtran
Its a 5.9 cummins 12 valve by the way
Old 08-05-2017, 11:44 AM   #3
Coachwork: myself
Chassis: amtran
So it's a bent push rod. Anyone know a good mechanic in chillicothe ohio? Or even a decent tow?
Old 08-05-2017, 12:08 PM   #4
Coachwork: myself
Chassis: amtran
I can't believe all the bad luck im having with this thing. I got the rod straight and it works now, but It doesn't sound right.
Old 08-05-2017, 12:26 PM   #5
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
The problem, and I am far from a mechanic, is something caused the bent rod. Timing? Wear? Need to figure that out before you do anything else. If you can limp it to a mechanic, that would be a good start.
Old 08-05-2017, 12:54 PM   #6
Coachwork: myself
Chassis: amtran
Thanks. Timing on a 5.9? Valves are not my speciality. It runs tho. Not well but it runs
Old 08-05-2017, 01:04 PM   #7
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Timing is in the fuel system on diesels. But valves are actuated by the cam. So fuel timing causing detonation? I am really sketchy on diesel engines. If the lifter isn't perfectly straight your probably not seating the valve all the way. If it isn't already damaged, running it is going to cause the valve seat to wear. If it wears too much, it could be the difference between a new push rod or a valve job, or even new heads.
The valve lash could have been out of spec to cause a bent push rod.
Old 08-05-2017, 01:05 PM   #8
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
Sorry, I am just throwing whatever I have gleaned out there.
Old 08-05-2017, 01:28 PM   #9
Coachwork: myself
Chassis: amtran
This is where I'm at? Without pulling the head I'm not sure how to tell
Old 08-05-2017, 01:51 PM   #10
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
You can check the rest of the valves for lash. I don't know if you can change 1 push rod. The lifter should be checked too.
Old 08-05-2017, 06:47 PM   #11
Did you adjust the valve with the cylinder on tdc.
Trailer2 is offline   Reply With Quote
Old 08-05-2017, 06:54 PM   #12
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
That's a good point. You have to bar the motor over to tdc to check lash and adjust.
You would have to Google it, but you can adjust 3 cylinders at a time.
Your harmonic balancer may have tdc marked on it.
Old 08-05-2017, 07:35 PM   #13
Coachwork: myself
Chassis: amtran
I understand that part and did it correctly. Thanks tho
Old 08-05-2017, 07:37 PM   #14
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
It was just a shot. Was hoping that was a magic fix.
