Old 05-13-2010, 03:51 PM   #1
maj
Coachwork: carpenter
Chassis: spartan
Engine: 5.9 cummins
Vibration at Idle
Hi, I have a 1995 carpenter flat nose front engine, 40 ft. bus. It has a 5.9 cummins with 125,000 miles on it. It runs great but at Idle it vibrates the bus. If I take if just off idle it smooths out. I was told that is normal. I was wondering if I can do anything. Maybe get the idle turned up some? Any Ideas?
Thanks MAJ
maj is offline   Reply With Quote
Old 05-13-2010, 03:56 PM   #2
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Re: Vibration at Idle
My 86 Intl does the same thing. It drives me nuts at idle. I was going to try to bump the throttle a hair.
I'm hungry!
You Gotta Let Me Fly
Old 01-23-2011, 06:26 PM   #3
Engine: 5.9
Rated Cap: 45
Ok, I am not an expert, but this is what I found. I bought a set of used 7mm injectors due to a recent head change. I put it back together, and had a very rough running bus. (89 model with 5.9 BTA, and a VE rotary pump).
First make sure all cylinders are firing. Do this with a cold engine, and stay clear of the turbo. Start the engine and feel each exhaust flange. You will notice that each will warm within a minute. Often there is a cold one or two. Make notes on these.
Shut the engine down , remove the injectors from the cold cylinders. Have a shop check them for spray etc. Mine were not spraying, but dripping. You will see this with black smoke in the exhaust too.
6 new injector nozzles, the engine runs like a smooth diesel...
Remember, i am new to diesels, but have many years on Jet engines.
Apacheglen is offline   Reply With Quote
Old 01-23-2011, 07:59 PM   #4
frank-id's Avatar
poor Idle
If the engine has glow plugs, remove and check compression. Replace the plugs after noting the compression values. Add a quart of Power service to 20 gallons of diesel fuel. After 250-350 miles, check the compression again. Any increase of compression will be noticed and the idle will be improved. Doing a compression test is very important to check engine condition. Some times I add a quart of water thru the top of the engine with the air cleaner removed. Make the engine turn about 2000 RPM and pour water into engine slowly so engine does not stall. Place an empty paper box at rear end of exhaust pipe to give evidence of removed carbon. Keep engine at 2K rpms for a short time. Allow engine to idle for a couple minutes. This is a quicky tune up. Frank
idle time mcmasterp Short-Bus Conversion Projects 6 10-15-2011 01:19 PM
Warm Up Idle for Diesel Engine lornaschinske Conversion Tutorials and How-to's 3 09-14-2011 01:08 PM
Vibration and electronics? GoldenGate Conversion General Discussions 12 12-10-2010 09:07 PM
fast idle switch diagnostics frank-id Cummins Drivetrain 2 05-20-2010 11:42 PM
What's a normal idle RPM for a diesel? Ottomobile Conversion General Discussions 1 03-28-2007 09:54 PM
