Old 05-06-2018, 06:23 PM   #1
LRScout's Avatar
What alternator is this?
Hello- my alternator went out. It's making a loud noise and not charging the batteries. The bus is a '96 thomas with 8.3L Cummins Diesel. Here's a photo:
I see a lot of options online- do they have a standard bolt pattern, or is it bus specific? Do I need a one wire hookup?
Thanks!
LRScout is offline   Reply With Quote
Old 05-06-2018, 06:34 PM   #2
Looks like a standard Chrysler alternator. Likely where ever you replace it will require a core charge, so I would pull that one, take it to your local O'Reilly's or parts store of choice, and have them match it up to a new/reman unit.
Old 05-06-2018, 06:40 PM   #3
LRScout's Avatar
Thanks for the quick reply! I'm looking at the alternators on amazon that are a lot cheaper than the local auto parts shops. I guess my question is more about compatibility. Can I just bolt up any alternator meant for Cummins?
Old 05-07-2018, 11:33 AM   #4
Chassis: International 1753
Engine: 6.9 International
Standard denso style alternator. Remove it and see if there is a tag on it that describes the options or gives a part number. You can purchase new at many places, but I'd recommend going to a parts store to avoid any warranty issues. That, and they can also test it out to confirm that it's bad.
They're also rebuildable if you're so inclined.
Old 05-07-2018, 12:01 PM   #5
replace that with a Bosch SB200 series...
Old 05-07-2018, 06:43 PM   #6
LRScout's Avatar
Thanks for the replies, here's what I found if anyone is in a similar situation:
Wilson 90-15-6424 160 amp alternator
compatible alternators listed on the Wilson site:
Delco 24Si or 24Si HP
Bosch E8
I had it tested at O'Reilly and it failed, has an audible bad bearing, and they wanted $245 for a re-manufactured one with $60 core deposit. I found a compatible one on Amazon for $95
The bracket where the alternator broke off on mine, so I'll be doing some welding too
Old 05-07-2018, 06:48 PM   #7
Chassis: Saf-T-Liner MVP ER
Bosch E8
Disconnect the battery negative and pull the plug from the Allison TCU before you weld on the engine.
Steve Bracken
Build Thread
Old 05-07-2018, 10:33 PM   #8
Yes...do as Twigg sez!
