Old 09-04-2016, 08:56 AM   #1
What should i take with me?
Next week i will drive me 97 Ford with 5.9 and Allison 643. The bus has been driven and started weekly bus other than that sat mostly for last 2 years with no sports trips.
Any tips on what additive should i or should i not put in the fuel? I was going to get a Fuel Filter or i for above and the one underneath. I was going to bring a long 5 gallons of Rotella. Anything wrong with not shutting it off once i head south from Des Monies to Kansas City 228 miles?
How would you do it?
I have pretty near every thread about the 5.9's. Will get verification of which 5.9 it is when i get there. Hoping of before.
Old 09-04-2016, 10:15 AM   #2
Lots of folks add one small bottle of 2-stroke oil to each tank of fuel. It adds back the lubricity that most of the "new" diesel fuels lack.
Old 09-04-2016, 10:37 AM   #3
Thanks. I had no idea.
Old 09-04-2016, 08:03 PM   #4
Rated Cap: 40 Prisoners
If the fuel is in question you can add PRI-D fuel additive to bring old
fuel back to refinery fresh. Also use properly it will allow you to store
fuel up to ten years.
Old 09-05-2016, 11:23 AM   #5
Thanks i will.
Old 09-05-2016, 02:05 PM   #6
I let my bus run at almost every fuel stop unless im checking the oil or such.. on my current trip it ran for 16 hours straight.. Ive learned how much oil it uses and such.. so even on my 60 minute rest breaks I let it run (so id have air-conditioning).. truckers leave their diesels run for long periods of time when on trips.. until you learn your bus i would shut it off and check the oil often...
every other tanbk of fuel ive been running 16 oz of Diesel Kleen.. it sup[posedly adds back in the additives needed in the fuel for older engines.. I only have a 25 gallon tank so I dont run a whole bottle.. and i do it every other tank.. ive put 8000 miles on my bus in the 4 months Ive had it with no issues..
Old 09-05-2016, 02:22 PM   #7
2kool4skool's Avatar
This is the best additive comparo I've seen.
http://www.jatonkam35s.com/DeuceTech...itive_test.pdf
Don, Mary and Spooky the cat.
Old 09-05-2016, 02:50 PM   #8
crazycal's Avatar
Number 7 is what I use. I buy it by the gallon at WallyWorld. It costs $12.88 per gallon. I also buy Number 10 but I don't use it as much.
I'm hungry!
You Gotta Let Me Fly
Old 09-05-2016, 03:09 PM   #9
once you burn off the old fuel and get fresh stuff you will be ok, it wont take long burn if off, I don't see the point of letting it idle all the time, unless your having a hard time starting it, I don't idle mine unless its needed, otherwise your just burning fuel, $$
Old 09-05-2016, 08:03 PM   #10
About the only real argument for idling a diesel is to allow a turbo to cool down. The enormous amount of heat they build up can cook the oil in their bearings unless you let it idle for 5-10 minutes.
