Old 08-13-2015, 02:07 PM   #1
When in doubt, follow instructions!
Had a bit of oily drippy stuff under the bus engine. All in one spot really, kinda looked like oil. The front axle and such is a bit road grime covered.
I'd park in a paved lot (at home I park on gravel), walk away and see a few drops of "oil". Crawled under and looked around, tightened the pan bolts a bit, not loose.
No oil use after a couple thousand miles...hmmm.
A couple weeks ago installed a drain hose on the engine mounted fuel filter canister just because it didn't have one. A nice long hose that ended a few inches from the ground. Didn't drive the bus a for a while.
Took a little trip and now I have fuel dripping from the hose....
OK, the drain valve is leaking...wrong. The canister is weeping around the seal area and running down ONTO the drain hose, following the hose, looking like it's coming from the hose. Drip, drip, drip every 2-3 seconds while running.
Months ago I changed the fuel filter, used a large open end wrench of the proper size..1-1/8in.
Yesterday, went online, checked for proper torque...25 ftlb is the generally expressed torque, Cummins says HAND TIGHT!
The "oil' was simply fuel that had gotten all over the front underside and having solvent properties turned the undercarriage greasy grunge into liquid, oil looking stuff for sure. The amount of torque from the 18in long wrench had apparently distorted the filter housing lid/O-ring 'cause it sure doesn't leak now. BECAUSE IT'S HAND TIGHT
Lesson learned...I hope
Don and Mary
dond is offline   Reply With Quote
Old 08-13-2015, 09:33 PM   #2
roach711's Avatar
Rated Cap: 19
Experience gained is directly proportional to equipment ruined.
Old 08-21-2015, 12:48 PM   #3
More drips...It's coming from the drain valve, the o rings are leaking internally. I went to Diesel Bombers etc and nosed around. Common problem, easy fix. new valve is $14 (Geno's Garage). Some just plug it and if there's a to need drain the housing, suck it out.
Don and Mary
Old 08-21-2015, 12:50 PM   #4
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
QFT!
I'm hungry!
You Gotta Let Me Fly
Old 08-21-2015, 04:09 PM   #5
I love a cheap fix...but a GOOD cheap fix is even better!
Old 08-23-2015, 10:12 AM   #6
Well my new part hasn't even shipped so I got bored and picked up some proper sized fuel rated O rings ($3.20) and re ringed the valve. Took a few minutes to reinstall and no more leaks. Guess I'll have a spare valve when it ships.
Don and Mary
Old 08-23-2015, 10:49 AM   #7
I hate waiting on parts. I ordered an inner tube three weeks ago and just finally got it.
Old 08-23-2015, 01:07 PM   #8
schoolmarm's Avatar
Year: 1985
Coachwork: Wayne Chaperone
Chassis: chevy
Engine: 350
I ordered a new shirt over a month ago, still has not arrived.
schoolmarm is offline   Reply With Quote
Old 08-23-2015, 02:50 PM   #9
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Hopefully it's not your only shirt?!
Hank's P-O-S is offline   Reply With Quote
Old 08-23-2015, 07:13 PM   #10
schoolmarm's Avatar
Year: 1985
Chassis: chevy
Engine: 350
Hank, fortunately I do have a spare. I don't look good nekkid anymore! LOL
Old 11-24-2015, 05:47 PM   #11
2kool4skool's Avatar
Ok...the fuel leak saga continues.
O rings and such do have a finite lifespan. The ones on 2K4S have a 15 year (196,000mi) life.
More fuel filter canister leaks, condensed story:
Replaced the O ring on the block off plate for the optional fuel heater, the water in fuel sensor and the sealing washers for the fuel in and out banjos. Leak free as I can be, at least for now.
Don, Mary and Spooky the cat.
