Old 04-26-2017, 10:35 AM   #21
I-77 is where in November, driving DEV, an unpredicted storm came up and had me on Black ice and 60 MPH winds on the WV turnpike...
I-77 on this last trip north in RedByrd I got caught in 100 miles of nearly Blinding Rain heading into Virginia from NC...
yeah I-77 has wierd energy!!
Old 04-26-2017, 08:46 PM   #22
Chassis: ford e350
Engine: 7.3 powerstroke
He he, I made it home , the last 200 miles were slightly nerve wrecking. Again a second hesitation and service engine light soon on.
Then about 20 miles from home on I99 around Altoona I faint smell of diesel came in the cabin. Optimist as me , haha, ....probably the truck in front of me...but the better part of me new that i had a fuel leak somewhere. The engine valley is wet so fuel pump? It has 150000 miles, so very well possible. It was night and I knew i could not fix it on the road, I checked my fire extinguisher and had some extra water ready in case things would get out of hand.
Either way, came home safe . Left a puddle of diesel on the street where I had to backup to get in the parking spot. Cleaned the puddle , opened the hood to let the heat out and also took the doghouse of.
See if it starts tomorrow and see if the diesel is coming from the weep hole , lines , filter or something more complicated.
Later J
Elfie is offline   Reply With Quote
Old 04-28-2017, 04:24 PM   #23
Chassis: ford e350
Elfie fuel leak
Well I tore the Elfie apart.
The leak comes from the fuel pressure spike reduces that is mounted on the y piece that directs the fuel to each cylinder bank.
The problem is how to get to it in an easy way
Later j
Old 04-28-2017, 08:22 PM   #24
Chassis: ford e350
Elfie MPG
Trip to Wilmington NC Outer banks
started with 245/70/R16
145829 miles 31.097 gallons
146190 24.843 361 miles 14.53
146578 28.209 388 miles 13.75 Mpg
146960 28.210 382 miles 13.54
147135 14.171 175 miles 12.349
????? 10.002
147699 31.219 564 miles 13.68 MPG
In the mean time some fuel receipts with the slightly larger tires
235/85/R16
Trip to Outer banks Miami Ocala Atlanta
148435 miles 30.342 gallon
148760 24.509 325 miles 13.260 mpg
149141 28.736 381 mile 13.258
149508 27.115 367 miles 13.534 Mpg
149937 31.273 429 miles 13.717 Mpg
150154 15.963 217 miles 13.593 Mpg
With the slightly larger tires the miles must be multiplied by 1.04 and so does the MPG
Later J
Old 04-28-2017, 09:38 PM   #25
Chassis: ford e350
Today had the heavenly taste of working on Van based engines.
This did not start to bad.
The 7.3 powerstroke fuel pump damper was leaking.
Location is a bi.ch.
School Bus Conversion Resources - Elfie's Album: Elfie the Elf Bus adventures - Picture
Yes right there under the turbo, i was able to get an open wrench in there and loosen it up but could not get it out.
So tore some more off.
On my other van i had done similar jobs and it was not to bad until I decided to take a shortcut and the top bolt of the exhaust pipe to the turbo Y broke off.
It was loose and came out nice but the last 5/16" broke of . In my othet Van i had drilled a pilot hole into the turbo Y and put WD40 in it. Did that now also but after it broke off. Anyhow my shortcut took me 4 hours to drill and re-tap the hole.
I had a used spare damper and was able to screw that on.
Tomorrow I will install the exhaust again and see how it runs.
The fuel damper had a crack in it.
Later J
Old 04-29-2017, 09:29 AM   #26
Chassis: ford e350
here a photo how I drilled out the broken of piece and how to prevent these things from happening on these powerstrokes.
I hope visible in the picture are the two small holes that end up in the blind holes of the turbo Y. Now you can fill that up with your favorite penetrating oil.
The tool is a HB freight buy. It did the job, $5 very well spent.
Going to install EGT probes while i am at it, but that is more in the build thread.
Later J
