Today had the heavenly taste of working on Van based engines.
This did not start to bad.
The 7.3 powerstroke fuel pump damper was leaking.
Location is a bi.ch.
School Bus Conversion Resources - Elfie's Album: Elfie the Elf Bus adventures - Picture
Yes right there under the turbo, i was able to get an open wrench in there and loosen it up but could not get it out.
So tore some more off.
On my other van i had done similar jobs and it was not to bad until I decided to take a shortcut and the top bolt of the exhaust pipe to the turbo Y broke off.
It was loose and came out nice but the last 5/16" broke of . In my othet Van i had drilled a pilot hole into the turbo Y and put WD40 in it. Did that now also but after it broke off. Anyhow my shortcut took me 4 hours to drill and re-tap the hole.
I had a used spare damper and was able to screw that on.
Tomorrow I will install the exhaust again and see how it runs.
The fuel damper had a crack in it.
Later J
