Old 12-21-2016, 03:23 PM   #1
Our new bus!!!
Sent from my SCH-I545 using Tapatalk
Qya1991 is offline   Reply With Quote
Old 12-21-2016, 03:24 PM   #2
Time to get to work.
Old 12-21-2016, 03:57 PM   #3
Welcome...now, get after it and keep the pix coming!
Old 12-21-2016, 04:14 PM   #4
GreyCoyote's Avatar
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
Wow! Under-skirt storage boxes! Thats a win!!!
Congratulations!
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
GreyCoyote is offline   Reply With Quote
Old 12-21-2016, 06:25 PM   #5
Thank you. I will keep them coming. Yeah I thought that was a plus as well. Thank you.
Old 12-21-2016, 07:05 PM   #6
So I started removing the seats. What's the easiest way to get the floor heaters out and all the hose underneath the bus?
Old 12-21-2016, 07:30 PM   #7
rossfree's Avatar
Coachwork: Chevy
Chassis: Ward?
Engine: 8.2 liter ?
Rated Cap: 24 Passenger
Sweeeet! Welcome!
Ross
rossfree is offline   Reply With Quote
Old 12-21-2016, 08:37 PM   #8
Carytowncat's Avatar
Welcome, glad you both are here.
How exciting!
Old 12-25-2016, 08:39 PM   #9
zelseman's Avatar
Engine: 6.5L Turbo
I would start by locating and shutting off the valve under the hood that controls the coolant to the rear heater. Then grab a bucket and unhook the coolant hoses from the heater and drain the coolant from the lines. Then it's as simple as pulling the heater out and rip the lines from under the bus.
Good luck and post some more pictures once you get started!
Okienomads 2000 Chevy Short Bus
Website
Instagram
Married couple full-timing in the American West-April 2018
zelseman is offline   Reply With Quote
Old 12-25-2016, 09:12 PM   #10
Rated Cap: 65 pax
Welcome and heed the heater advise... I ended up having to mop up a lot of coolant
I look forward to seeing your progress.
Sandi
www.thismidwifetravels.com - bus pics
WanderWoman is offline   Reply With Quote
