Old 10-22-2017, 06:46 PM   #1
Romani Bus's Avatar
Year: 2005
Engine: International
What are the best generator mounting options when towing a vehicle?
What are the best Generator Mounting Options when towing a vehicle? My wife and I have a 40 foot international school bus that’s been converted. Without cutting into the side skirts of the bus, what are the best options for mounting or carrying a 10,000 W generator? We will be towing a 2006 Jeep Wrangler that’s been lifted behind the bus. I was thinking of getting a heavy duty cargo carrier that I could then attach a ball hitch behind and then attach the jeep to it.
Romani Bus is offline   Reply With Quote
Old 10-22-2017, 07:44 PM   #2
Chassis: Blue Bird
Engine: ISC 8.3
The idea of towing through a hitch-mount cargo carrier doesn't sit well with me, especially at the tail of a front-engine bus. That's a long lever between the rear axle and the ball mount on a cargo carrier out back. I don't have any idea how much force it takes to put a bend in a hitch extension like that, but the long leverage would have to help make it possible.
Maybe you could clarify whether the generator is simply to be hauled and you'll set it somewhere when parked and wanting to run the generator, or whether you're looking for a place to mount it for both transport and operation (and maybe operation while underway).
Inside the bus or Jeep come to mind. Hitch carrier on the back of the Jeep does, too. Reconsidering whether you really need 10 kW might also be in order; for many folks that's quite a lot of generator.
Old 10-22-2017, 07:53 PM   #3
Romani Bus's Avatar
Year: 2005
I would ideally like to mount the generator and keep it mounted. I would like to have the ability to open the back door of the bus if we need to. The only thing that we would necessarily have to run on the generator would be the AC unit and the lights and at times the refrigerator. What size generator would you recommend if you feel that that one is too big?
Old 10-22-2017, 08:35 PM   #4
I'd recommend a 3K inverter quiet generator like a Honda or a Yamaha. Both make high quality low db units that will do what you need. New is best because of the warranty but a good used unit can be had on ebay or Craig's list--just insist that they be serviced and checked out by the appropriate dealer. I use a 3K Yamaha on my bus to run a 6k btu ac, 900 watt microwave and mini fridge without any problem as far as power generation is concerned. If I add a 45 watt converter to the system it pops the circuit breaker in the distribution panel but doesn't seem to bother the genny. I kind of have to play "Green Acres" with my electricity usage but thats not the fault of the genny. . Jack
Old 10-22-2017, 11:47 PM   #5
Oh, wait. This one is better:
Old 10-22-2017, 11:52 PM   #6
Chassis: Saf-T-Liner MVP ER
Could you elaborate a little on why you need a 10kW generator, and why you have ruled out the obvious solution, when the solution you proposed is actually more difficult?
Steve Bracken
Build Thread
Old 10-23-2017, 01:58 AM   #7
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Why not cut into the skirts? She don't mind.
10Kw genset is pretty heavy, you would want it near the rear axle. I have a 10Kw Onan mounted in a slide-out sound enclosure. Seems to be a good system, Coachbuilder installed it there.
Old 10-23-2017, 05:28 AM   #8
Attachment 16816
Yeah, its best to have the weight between the axles, like BB did with your bookmobile.
Roll Your Own Build Thread
Old 10-26-2017, 08:40 AM   #9
Romani Bus's Avatar
Year: 2005
We found a solution!
We decided to go with a smaller inverter generator. We are going to mount the generator on the back door of the bus. We are having a friend weld up a platform with brackets that will bolt with backing plates straight through the back door on the bottom. The generator that we got it’s just about 95 pounds. We can leave it there while we travel and it will be easily removed if we want to run it away from the bus. Also, we are installing a under carriage box for two propane tanks. Making it easier for us to utilize two regular 20 pound propane tanks. I’ll post photos as soon as we have everything mounted.
Old 10-26-2017, 10:33 AM   #10
id be concerned about adding 95 lbs to the hinges of that back door.. people on the jeep forums have gotten into trouble this way mounting larger than factory sopare tires on their back door / tailgate. the constant vibrating down the road creates forces greater than 95 lbs.. esp at the back of a bus where is pretty bouncey.. the generator likely wont care but seems the back door isnt designed for continuous use of that extra weight..
cargo, generator, jeep, mounting, towing
