Bolted & welded 2' receiver to the tow hook plate, using (4) 5/8" grade 5 bolts, flat washers, split lock washers and nuts. Followed up with tack weld at each corner AND each bolt to ensure they will never loosen. A 6" drop hitch with a 2" ball results in a working height of 17" which is perfect.
Customizations
Tow Vehicle
2000 Toyota 4Runner Limited 3.4 liter DOHC V6 AT
Harbor Freight Tow Bar w/ 4 safety chains
Favorite Camping Destinations
Deepest, remotest parts of desert southwest. Chocolate Mountain Region. Washoe County NV. Quartzite, Deming, Nelson, Rachel, Toyaibe, Demio
We've got the same bus! I stumbled upon you while searching for the model. Question for you - does your have an ignition interlock system? If so, did you keep it intact or remove it?
