Thread Tools Search this Thread Display Modes
Lucille
meteoricide's Avatar
meteoricide meteoricide is offline
Registry
Vehicle Name Lucille
Year 2004
Make Navistar International
Model IC3S530
Length 218 inch wheelbase
2004 Navistar International IC3S530
2004 Navistar International IC3S530 2004 Navistar International IC3S530 2004 Navistar International IC3S530
Basic Info T444E 210 HP V8, Allison 2000 5 speed auto trans, Bendix Tu Flo 550 Air Compressor, Air brakes, Air ride suspension, Ricon lift. Dana Spicer 21k military rearend. GVWR 29000.
Exterior
2004 Navistar International IC3S530 Exterior 2004 Navistar International IC3S530 Exterior 2004 Navistar International IC3S530 Exterior
Bolted & welded 2' receiver to the tow hook plate, using (4) 5/8" grade 5 bolts, flat washers, split lock washers and nuts. Followed up with tack weld at each corner AND each bolt to ensure they will never loosen. A 6" drop hitch with a 2" ball results in a working height of 17" which is perfect.
Customizations
2004 Navistar International IC3S530 Customizations
Tow Vehicle
2004 Navistar International IC3S530 Tow Vehicle 2004 Navistar International IC3S530 Tow Vehicle
2000 Toyota 4Runner Limited 3.4 liter DOHC V6 AT
Harbor Freight Tow Bar w/ 4 safety chains
Favorite Camping Destinations
Deepest, remotest parts of desert southwest. Chocolate Mountain Region. Washoe County NV. Quartzite, Deming, Nelson, Rachel, Toyaibe, Demio
Old 07-12-2018, 05:26 PM   #2
Hi Meteoricide!
We've got the same bus! I stumbled upon you while searching for the model. Question for you - does your have an ignition interlock system? If so, did you keep it intact or remove it?
HippyCamper
HippyCamper is offline   Reply With Quote
Search this Thread:
Advanced Search
