Old 09-23-2014, 05:16 AM   #41
Re: 120/240V household water heater installed and working
I will try heater on 120v this weekend and results
Old 09-23-2014, 01:51 PM   #42
Here is a cheap and easy Automatic voltage selection. The relay (contactor) should have 30 amp contacts with a coil voltage for 208-240. Connect the shore power neutral to the Normally Closed contact/ Normally open to the one of the Hots. Shore power should be from a 30 amp DP circuit breaker. If you use a DPDT relay the extra contacts could be used for an indicator light.
Pops is offline   Reply With Quote
Old 09-23-2014, 02:17 PM   #43
great info thanks!
Old 11-01-2014, 12:06 PM   #44
Well? This is the sixth weekend.
Old 11-01-2014, 04:58 PM   #45
I know...shame on me...it did work tho'...I forgot and turned it on Friday and on Sunday I was like CRAP....bus was still there and there was hot water, as for recovery...dunno...because I turned it off
After this last trip, I plan to install a tube/shower so if mother nature works with me..I will have some numbers
It does work...just not sure if its "usable" it has to be better than a 6gallon one, just due to mass of water...ugh right
Old 12-13-2016, 06:44 AM   #46
this is bumped because some asked about a water heater a week or so ago
Old 12-13-2016, 11:30 AM   #47
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Nat had a good suggestion on this, Install a 240v water heater change out one of the heater coils to 12v to run off your battery bank so it would heat while driving, problem is I've been online searching & haven't been able to find a 240v water heater in the 10 to 20 gallon range.
Hydronic heater and hot water DaveLind Conversion Tutorials and How-to's 1 08-27-2014 09:39 AM
Rv Fridge and Rv water heater kenny76 Classifieds | Buy, Sell, Swap 6 06-02-2014 12:13 AM
Diesel water heater Luke Conversion General Discussions 5 02-07-2009 11:52 PM
Bus engine as a water heater Steve Conversion General Discussions 20 07-07-2006 02:53 PM
Time to buy a water heater vonslatt Conversion General Discussions 4 03-04-2005 01:01 PM
