Old 02-20-2010, 12:46 AM   #1
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
12V bulbs and current draw.
Anyone have a chart of common automotive bulbs and their respective current draw? I am trying to figure out an estimate of my electrical needs and this would help. Also, has anyone replaced their interior lighting with LED bulbs and does it work well? All of the LED bulbs I have seen in the past have been quite directional and I don't think that they would be suited to interior lighting. Of course LED lighting takes much less energy than conventional incandescent lights. Hopefully I can come up with a reasonable setup, I would like nothing better than to be able to be completely off the grid for a week or two at a time.
Old 02-27-2010, 10:20 AM   #2
Re: 12V bulbs and current draw.
I saved some power in our boondocking camper by replacing turn signal bulbs with dimmer marker light bulbs. I also added a pair of LEDs in one fixture at reduced current to act as as always-on "night lights."
LEDs are the future, but the quality of what assemblies you can buy today is variable. There is no way to tell how well the individual LEDs in an assembly are powered, unless you wire them yourself. Price is no guarantee of quality at this point. Unless they are wired with voltage-independent current regulation, they will either:
1. waste power in heating up current-limiting series resistors
2. be efficient, but get dim fast as the battery discharges
3. be bright, but burn out on over-current when the battery is charged
I discussed this further on this thread: http://www.skoolie.net/forum/viewtop...p=43887#p43887
Old 02-27-2010, 04:42 PM   #3
lapeer20m's Avatar
if you compare watt/lumen compact florescent bulbs are far superior to led's
led's use less energy because they create less light....however that light can be in an intense focused beam.
cf bulbs are probably only a good option if you have an inverter that is already running other appliances.
1141 and 1156 Bulbs and Fire Hazzard browncrown Conversion General Discussions 6 07-24-2013 09:56 AM
12 volt mr 16 light bulbs chev49 Conversion General Discussions 1 04-30-2012 11:29 AM
What amp draw ok on common? GameRV Alternative Fuels | Electric, Propane, Wood & Biofuels 29 05-13-2011 05:42 PM
Use current RV as donor, or sell? Locutus Conversion General Discussions 7 05-21-2010 09:34 PM
Air Conditioner Amperage Draw CVanDamme Conversion General Discussions 8 07-06-2007 06:44 AM
