05-04-2017, 10:51 AM
24v inverter for my Bus?
I have been looking all over for a 24v to 120v inverter, Amazon has a limited selection and a lot of mixed reviews I am looking for a reliable brand with 1500-2000w of power.... Any feedback will be greatly appreciated! THANKS!
05-04-2017, 10:59 AM
Year: 198x
Coachwork: Crown & MCI
Chassis: 40ft Tandem/40ft MC-9 Tag
Engine: Cummins 855 BCT/6V92TA, RTO-910/HT-740
Rated Cap: 47,000lb/38,000lb GVWR
Try looking at Magnum Energy or Xantrex inverters. They have 12, 24 and 48VDC inverters.
05-04-2017, 11:05 AM
I looked at xantrex and the lowest price 24v is 900$ and that's 60% of what I paid for everything
05-04-2017, 11:29 AM
Year: 198x
Yeah, quality inverters have a high price tag. Personally, a Xantrex product is the "lowest" quality I'd go.
Keep an eye on eBay and auctions; sometimes you can get lucky and find a good high-quality 24VDC inverter salvaged from a high-end motorcoach.
05-04-2017, 12:13 PM
The same junk yard you might go to pick up a second hand awning should also have the electronics you need.
Robin
Nobody's Business
05-04-2017, 12:53 PM
Rated Cap: 37,400 lbs GVWR
I bought a refurbished Magnum MS2000 inverter/charger from Wholesale Solar in northern CA for $1000, little more than half the normal price. They may still have some other refurb Magnums, maybe? Magnum are made in USA, are completely serviceable (even mostly field-serviceable), and should be the last inverter you'll ever need. Don't waste your money on cheapo stuff - sooner or later you'll end up buying real quality anyway after the other one(s) have failed, so just buy a good 'un from the start! At the least, thoroughly research what others have experienced with whatever you plan on buying - there's plenty of informative YouTube clips on the good, the bad and the ugly. Some brands like Power Jack and AIMS need to be researched very carefully!
05-04-2017, 05:06 PM
+1 Magnum Energy are the best
05-04-2017, 06:11 PM
I have the 12 volt version of this one..
GP-SW1500-24
https://www.amazon.com/Go-Power-GP-S.../dp/B00153BE6A
its been fantaastic in the dev bus.. ive used it in hiot / cold, run it to its maxx for long periods of time.. I measured its output with a scope and its real nice sine wave..
05-05-2017, 06:25 AM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
I have the 24V Wagan 3744-4 ProLine 5000W. I haven't used it a lot since recent installation but it seems to work just fine. I purchased it from DonRowe.com for $470 and free shipping. I suspect they have one in the 2000W range but didn't actually look.
Depending on where you mount it, my only suggestion is to watch out for the ones with a noisy fan that runs all the time. That can get really annoying if within earshot.
Edit: Oh also... if planning automatic switching, be sure to consider the price of an Inverter with an internal transfer switch vs an external switch. And, of course, one with a remote on/off switch.
05-05-2017, 05:45 PM
I'm with cadillackid. I also have the 12v version of the Magnum MM1524AE. It is rock solid. Inverters are expensive though. You get what you pay for.
05-05-2017, 06:56 PM
So I found a almost new referb Xantrex PROSine 1800 24v for 410$ shipped or should I save up for a magnum or just use this till I can afford one?
05-05-2017, 07:00 PM
So I found a almost new referb Xantres PROSine 1800 24v for 410$ shipped or should I save up for a magnum or just use this till I can afford one?
I've heard good things about Xantrex actually. Just expect that under normal circumstances its not going to last as long as a Magnum equivalent. Look at the idle amp draw as well because that should factor into your decision. My Magnum pulls like 1/3 an amp with no load. And as already said check your model for reviews of excess noise unless you expect to mount it out of the way. That's what I did with mine. $410 isn't a bad price.
05-05-2017, 07:09 PM
Thanks for all your help I think this will be perfect for my setup it's 1300$ new.
I have 945w pv 40a mppt and 6, 12v 145ah agm batteries. I think I paid 1600$ for everything including the xantrex inverter now I just need to install
