Old 07-25-2017, 01:01 PM   #1
4x255ah batteries
What size is your battey bank. What can you run and how long. How many solar panels do you use to charge them
Freedomfinder is offline   Reply With Quote
Old 07-25-2017, 01:34 PM   #2
Rated Cap: 37,400 lbs GVWR
I will have eight golfcart batteries in two separate banks of four in series and parallel, giving me about 900 amp/hours at 12V. To charge them I have eight Sharp 255W panels totaling 2040 watts that power two Morningstar TS-MPPT-60 charge controllers. My intention is very simple - my solar will be enough for all my needs, including a 12K minisplit and heatpump in the front and a 5 or 6K window A/C in the bedroom, and I will have three days' autonomy if the sun doesn't shine for that long (but that's very unusual here). Along with that, I have 220 gallons of fresh water and 180 gallons of black and gray tanks, so I should be self-sufficient for at least a month off-grid by myself, or two weeks for my GF and I (he says optimistically!).
Old 07-25-2017, 03:57 PM   #3
turf's Avatar
4- 12V x 100AH batteries
400 AH - 50% depth of discahrge = 200 AH
charging by generator its impossible to top off the batteries. i shoot for a bit over 80%. that puts my bank around 160 usable AH. that's probably just over the daily use of my fridge. when camping, they need charged daily. i have no solar. the batteries charge on generator only. i like to run 1-2 hours of generator time per day. more is better!
Turfmobile Build Thread
