Old 06-20-2017, 11:59 PM   #1
'92 International idi 7.3 speed governor
Hello all,
Please forgive me if this has been well covered already, but i'm new here and the searching that i did didn't turn up a clear answer. Feel free to direct me to another thread, but please make sure the links are current if you do-i checked one out that seemed promising and it was dead. I have a '92 International shorty with a 7.3 idi engine and i'm trying to figure out how to disable or adjust the speed governor. It's a Sturdy brand, located on the passenger's side of the firewall, and it has both throttle cables and electrical wires going to/from it. And lest you try to discourage me from messing with it at all, it's currently set at about 49mph!
Thanks in advance!
Aaron
pianobus is offline   Reply With Quote
Old 06-21-2017, 01:08 AM   #2
first of all, the sturdy speed control has a website
Old 06-21-2017, 08:14 AM   #3
Chassis: International 1753
Engine: 6.9 International
Take some pictures of what you have and we can try and walk you through it. Most of the time you can open up the box and remove the gears that are inside of it and that will eliminate it. However sometimes you end up actually removing the system altogether and rerouting the throttle cable back to the injection pump.
Old 06-21-2017, 04:57 PM   #4
Here's the offender-should I take the cover off and take another photo? (Trying to do this in an iPhone, hope it attaches.)
Old 06-21-2017, 05:23 PM   #5
Yes, remove the screws that hold the cover on and snap another.
Old 06-22-2017, 09:08 AM   #6
Ok, once again, i don't know if this attached-we'll see shortly!
Old 06-22-2017, 09:11 AM   #7
Success! Also, there was a circuit-board that i removed to better see the gears.
Old 06-22-2017, 09:45 AM   #8
Those are the gears. The ones on the shaft held by the two phillips screws.
Old 06-23-2017, 08:31 PM   #9
That one gear did it-thank you!
Old 06-27-2017, 09:37 PM   #10
Crashmike's Avatar
Coachwork: Bluebird & international
Chassis: Bluebird
Engine: 7.3 i.d.i diesel n.a.
Rated Cap: 26
7.3 idi governer removal
On the box on the fire wall for the governor is their an updated pic. Of after you adjusted it
Crashmike is offline   Reply With Quote
Old 07-12-2020, 04:15 PM   #11
Update?
Hey Pianobus- have the same bus here. How did the governor removal work? Did it change how your engine ran?
TravisMJ is offline   Reply With Quote
7.3 diesel, governor, idi, international, sturdy
