Old 08-12-2019, 05:58 PM   #1
99 International Fuse Panel
Does anyone have a pic of the fuse cover I'm told I'm missing? Cover for the panel pictured. I need to know what #9 goes to (9th down on right side). We pulled the breaker cause it was bunring up. It has a short somewhere. I figured out why the tail light lens melted, I had the start batteries hooked up for 24 volts. It also popped a headlight.
Old 08-12-2019, 06:32 PM   #2
Never seen a cover on one.
Old 08-12-2019, 08:32 PM   #3
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
That's the chassis fuse block, I have the same one. I'm not going to the bus until thursday. I can snap a pic. All systems in that block are critical to run.
CMORGANSKOOL is offline   Reply With Quote
Old 08-12-2019, 08:54 PM   #4
Curious as to what that fuse powers. Everything is working except we couldn't find the back up wire. On a side note....... that breaker had a piggyback terminal on it , nothing connected to it.
Old 08-13-2019, 10:07 AM   #5
Coachwork: IC
Chassis: FE Bus
I spent a half hour looking through google to find a pic of the fuse panel cover. Nothing!!!
I had a pic on my phone too. Nothing!!
You think with millions of these buses out there there would be tons of resources available
I think it's the rg head light
http://www.skoolie.net/forums/attach...1&d=1543704011
Old 08-13-2019, 11:18 AM   #6
Link doesn't open. What is RG? Headlights work without thta fuse/breaker in the slot.
Old 08-13-2019, 12:09 PM   #7
Coachwork: IC
Chassis: FE Bus
Found an old diagram from the 90s
Thought it may be rt head light. Or low beams.
Probably different on ours.
Old 08-13-2019, 01:58 PM   #8
Well the rt headlight was blown, so I don't know it just blew or has an issue on that circuit.
