07-08-2019, 08:54 PM
#41
I've worked teaching English
and can't figure out the meaning of your post.
07-08-2019, 11:44 PM
#42
English teacher? This new millenial generation must make you want to kill yourself doesn't it?
07-09-2019, 06:59 PM
#43
I know im new, but its pretty disrespectful of you to act like that. There was nothing wrong with his post. If you want to be petty its pretty rude to carry on unrelated conversations in someones specific thread like you have been.
The topic is ac vs dc generation from a generator. Not battery charging technicalities, not solar, nor is it vharge controllers.
07-09-2019, 09:12 PM
#44
Don't know who you are referring to, but it sounds as though you're experience on the internet is going to be quite disasppointing.
07-09-2019, 09:14 PM
#45
John, acting like the dc before batteries comment is somehow intelligible.
07-09-2019, 09:15 PM
#46
I was indicating that I quite literally could not extract their meaning.
Perhaps a typo, I dunno
07-09-2019, 09:16 PM
#47
Converting back and forth between ac and dc before the batteries is inefficient.
Not trying to be rude but it was pretty obvious.
07-09-2019, 11:35 PM
#48
I missed it as well, so perhaps not so obvious.
07-09-2019, 11:39 PM
#49
Chassis: IH 3800, 8 window
Too bad Google Translate doesn't interpret electrical shorthand.
10-02-2019, 09:49 PM
#50
Anyway, I decided on a DC based system. Which really just means a DC generator I guess. I have a Leece-Neville 48v 90 amp alternator off a John Deere 2500e in the Mail I got from eBay. It’s a nice alternator because it’s designed to run batteryless which I assume means it runs at a high duty cycle without issue.
As far as an engine, I have a line on a few yanmar 3cyl diesels locally. Haven’t decided if I want a “66” “70” “76” or “78” though. There’s a decent looking “70” close by and I hope to take a look before it sells.
All in all I’m looking at $1000 total between the two for 5kw of dc power. Used 5000w 120v military diesel generators go for 3000 so I’d say it’s a decent deal for sure.
10-02-2019, 11:12 PM
#51
Chassis: TC2000-8 Window
Engine: Cumm ISB/Allison 2000
If you are still looking at 48v Air Conditioning units, there is a 12k btu unit that does not need converting from marine life. To me it's a little pricey.
https://www.hotspotenergy.com/DC-air-conditioner/
10-02-2019, 11:26 PM
#52
I’m not sure about A/C units.
I’m still deep in the planning phase of a build, don’t own a bus or anything. But I’m serious about it and I picked electrical to start buying equipment for. I figure if for whatever reason the plan switched to one of those tiny homes on a trailer, the electrical system would still be the same.
And it would be “fun” to build a little generator that I can play around with until I get the big toy.
10-03-2019, 02:35 AM
#53
Indeed it would!
10-11-2019, 08:22 PM
#54
I am so lucky, apparently the 56v version of my alternator is the exact same alternator with a different regulator and after 20+ emails with the manufacturer and some of their distributors I literally have the last regular on the planet that the manufacturer had.
Now to see if a fixed 56v power supply can charge a lifepo4 battery adequately. I don’t care if I get 90% charge or whatever. As long as the battery will function reliably.
Oh, and both Yanmar’s that I’m looking at are still available as of today. So it looks promising that at least one will be there next Friday when I get paid.
10-18-2019, 02:10 AM
#55
The 12.5kw (mechanical) engine is scheduled to be delivered tomorrow. I can’t actually start it once t gets here due to living in an apartment and not owning a truck but it’s finally seeming more real. Alternator- owned, engine- on its way, serpentine pulley replacements for the v belt water pump and crank- ordered. Once I have the inverter it’ll be fully functional seeing how the alternator is 100% duty cycle rated and shouldn’t need a battery.
Now how to “spend” my other 7kw of output. Another alternator? A air conditioning compressor? York ac compressor setup for compressed air? All of the above?
That’s the real beauty, no bull crap mass produced single use piece of equipment but a custom tailored power plant designed to take on as many tasks as I can need. I haven’t even gotten to discussing the use of the coolant as radiant floor heat.
10-20-2019, 12:41 PM
#56
Let us know how that works out for you.?
One recommendation : carry lots of fire extinguishers.
10-20-2019, 02:08 PM
#57
I don't even understand what that's supposed to be about.
What alternator doesn't need at least a cheap lead batt to prevent load dumps, frying its diodes?
10-20-2019, 03:50 PM
#58
Year: 86
Chassis: Ford B700
Engine: 8.2
you have an idea going and i wont discourage it but a little advice if you dont mind?
you are looking at and getting deals on things?
good.
now for your alternator? you talked to the manufacturer and are getting the last one made? what is your replacement when it fails?
with your entire idea of building your own electrical system i say go for it but where in the world would your 12kw gennie fit on a bus? unless you trailer it?
my build with 12v lights and electric heat and a dorm fridge at our stage can run can run off of a 2000 watt gennie. most use a 6-8000 watt generator not anywhere close to a KW GENERATOR.
GOOD LUCK WITH YOUR DECISIONS.
10-20-2019, 04:01 PM
#59
Year: 86
Chassis: Ford B700
Engine: 8.2
WHAT I originally meant to say was there is not a single alternator out there that ever needed a battery? the battery needed the alternator to charge it? maybe technology has changed and i am to old school?
but it was always the battery needed the alternator to charge it?
unless there was an alternate source to charge the start batteries because the alternator only charges if the engine it is connected to is running?
10-20-2019, 04:04 PM
#60
good.
Ok, I'm new, so I will take one for the team.
1000 watts is one kilowatt
Have a great day all
Steve
