Old 04-13-2019, 08:51 PM   #1
Abs light on
i have a 2007 international dt 466 ce300 school bus with air brakes. Anyone know of any notorious problems i should check that could shut off an abs light
Sp6saz is offline   Reply With Quote
Old 04-14-2019, 09:44 AM   #2
ShagNasty's Avatar
Chassis: Thomas
Engine: Dreaded 3126 - 545
Sp6saz,
If you have disconnected your battery or it has died recently then the ABS module needs to be re-set. On my Thomas 2002 that is done by driving the bus and at approxamatly 3 MPH the light will go off and all codes will be normal. If that does not work then there is probably an ABS blink code switch that you can retrieve the fault for.
Dan
ShagNasty is offline   Reply With Quote
