You need to get better acquainted with your system and basics of DC electrics.
Laptops can use a lot of Ah per 24hrs depending on specs and what you're doing.
I bet you have other loads too, the compost toilet fan as you stated, also in the galley, lighting, ventilation, pumps?
Your MPPT SC has no clue about bank SoC%
Get an Ah-counting battery monitor, and get to know how many Ah you use in total each 24hrs.
This must be kept lower than your daily energy inputs, whether alternator, solar or a portable genny.
Called an energy budget, worksheets available online.
Sitting below 100% SoC for long does damage batteries, but it may not be obvious, just drastically reduced lifespan.
A bank that could last 6-8years coddled can be murdered in a few months if abused.
The charge specs, definition of 100% Full from your battery maker is critical, please get and post that first.
You need a decent ammeter and DMM, ideally known accurate voltage capable of being calibrated, and to learn how to use them.
Try to avoid using the inverter, phones and other devices with batteries should be run directly off DC. Inverter should only be turned on when actually needed, ideally with charge sources active.
And obviously getting as much solar as will fit on the roof, maybe a portable gennie.
Don't replace your bank yet until you know how to care for them, unless they're completely shot, or you'll just do the same again to the new one.
Very few RV industry professionals know much about this stuff for an off-grid living use case,
put in a bit of reading, googling, asking smart questions and you will soon know more than 99% of them.
DC Electrics 101 learning thread
http://www.cheaprvliving.com/forums/....php?tid=28197
