Old 10-24-2012, 12:36 PM   #1
Diesel Dan's Avatar
Engine: DT466/AT545
AGM battery question
Am I correct that if I get a sealed AGM deep cycle house battery that I will not need to worry about venting it to the outside, and that likewise I could put the inverter in the same compartment with the batteries and not worry about the electronics getting corroded? This is not actually for my bus, but rather will be used as a portable power station that I can use in my other vehicles. Just a single small 12v 56AH battery paired with a small 400w inverter, both in a wood box with carry handles. Something like that... to be used for low amperage items like lights, fans, computer, radio, etc.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-24-2012, 03:00 PM   #2
Chassis: TE2000 FE
Engine: 5.9L Cummins
Re: AGM battery question
That is correct, AGM batteries are sealed and do not vent corrosive gases.
Chuck
cschlessman is offline   Reply With Quote
Engine Battery question Leftyclick Mechanical and Drivetrains 1 11-17-2014 01:44 PM
House Battery Question Tango Alternative Fuels | Electric, Propane, Wood Gasification, etc. 3 10-06-2014 09:17 PM
Battery charging question Diesel Dan Electrical, Charging and Solar 1 04-29-2011 04:47 PM
Battery Storage question swinada Everything Else | General Skoolie Discussions 8 10-20-2007 04:32 AM
Battery question -- won't take charge Elliot Naess Everything Else | General Skoolie Discussions 6 03-31-2007 02:23 AM
