Thanks im sure this will come in handy later on. I also have a 1999 AmTram with a DT466E, AT545. Im looking to figue out about weather or not to keep trans
alot has to do with what your travel plans are and how heavy you will be. running loaded down and towing a trailer or car over hilly terrain will quiite possibly spell the end of that transmission..
at the very least you'll want to put a nice big cooler on it.. no doubt there are better transmissions out there... however there are a lot of people running 545s in their busses as well.. to me, the biggest successes have been with those not running heavy busses or towing large weight.. and not trying to win speed records by running flat out.. taking it easy will increase the longevity of that transmission..
One question though, as I have a 1997 Genesis FE. Anyone know how much the electrical system differed between FE/RE, and possibly how much it changed between those two years?
Hi everyone,
I have a 2002 international Amtran RE and I had recently added a second stop arm in the rear of the bus. I simply connected the lights and motor directly to the front stop arm and it worked flawlessly. While wiring the back stop arm in a more sturdy and permanent fashion I actually crossed a positive wire with a ground, there was a loud pop in the front of the bus(I'm assuming from the fuse panel) and now the motors for both front and rear stop arms and even the crossing gate now do not engage. They are all electrically operated, not air operated. The lights on the stop arms still work which leads me to believe that when the wires crossed that it blew a fuse. I've looked many spots but I'm not able to find a fuse for the stop arm or crossing gate, or really any fuses at all for that matter.
Can anyone direct me to where those fuses may be located? From reading my issue, could there be any other solution other than a blown fuse? Any other suggestions?
Hi everyone,
Thank you in advance!
- Tyler
On my 99 the panel is on the outside under the drivers window. It's more circuit breakers than fuses.
Chassis: Amtran RE T444E
Engine: 7.3
Diode Pack in rear electrical center
Hello all, I have a 1998 Amtran RE, and I have a connector in the rear electrical panel with 2 diodes attached to it. One of the diodes is burnt, and it wont start unless I jump over that diode. Does anyone have the schematic relative to this and the ignition system. I have looked through the uploaded schematics on this thread and don't see any ignition schematics(thanks for the uploads, by the way) I need to know where those diodes go or come from. Thanks for the help. Here's a picture of the diodes
"If you can't take the heat...Don't poke the Dragon"
Nice catch, to find a bad diode that is!
Diodes are easy to test using a ohm meter!
Those diodes should have a number imprinted on them. If there are two, then most likely they will be the same.
Check to see what numbers they have on them.
I'll be happy to look at the service manual I have and upload the diagram, if I have it that is. I got to be on the road today so I won't be able to look for it till this evening.
Is this connection part of the "VIM" big black box with the rear key switch start in the rear engine compartment?
Can you upload a picture with more background detail of the connection/area in question.
Also, do those red wires with the diodes, do they numbers on the wires themselves? This might help me identify the circuit.
Looking thru the service manual I think I found the connector/circuit in question.
The diodes appear to be simple low voltage diodes, probably something like a 1n4006 ??? Look at the numbers on the other diode. Since their are no more radio shacks, I would try to find a tv repair place, if they still exist, they would have them for sure. Very common diode.
If not, then order from Newark electronics.
Having that solid wire there in place for testing purposes is ok but I would without fail, replace it with a diode. The purpose of that diode in the circuit appear to be to prevent a backfeed to the adjacent circuit.
I uploaded the diagram, 3 pages in total. You will see the diode circuit on page 1, along the right page edge, middle of page edge.
Again, that was a real nice catch finding that burnt diode. I have been in my control box several times and the way that diode assembly was tucked in there, never would have found it in a million years!
Now I have a favor to ask of you.
Do you have a push pad tranny?
If so can you do a test for me?
Pull out that jumper wire, no diode in place, and just turn the key switch to the "On" position, not start!
What I want to know is if the tranny push pad is either lit or is it dark with out that diode/jumper wire in place.
This might be very helpful to other who have a no start and dead push pad.
