Old 04-22-2017, 08:27 PM   #1
Coachwork: Blue-Bird
Engine: 5.9
Back up lights
As I am trying to finish up and get my bus on the road. But my backup lights and back up alarm are not working. Any help appreciated.
David Moose
Moose is offline   Reply With Quote
Old 04-22-2017, 08:35 PM   #2
Chassis: E-450
Engine: 7.3 Turbo
Have you checked fuses?
PigPen is offline   Reply With Quote
Old 04-22-2017, 08:38 PM   #3
Engine: 5.9
no I haven't . I will have to pull and check each one I guess. No info on fuses available here
David Moose
Old 04-22-2017, 08:46 PM   #4
Chassis: E-450
Engine: 7.3 Turbo
Were they working before and just stopped or have they not been working for a while?
If it were me, I'd at least start with checking connections and fuses. It sounds like you don't know which fuses you need to check. Do you have a multimeter? If you do, most fuses can be checked without actually pulling them by using the exposed metal on top (holes in plastic) to check for continuity.
Old 04-22-2017, 08:50 PM   #5
Also, any idea if they went out at the same time?
tlbeck1985 is offline   Reply With Quote
Old 04-22-2017, 09:15 PM   #6
Engine: 5.9
Don't know if they were ever working. I replace the old backup alarm and when I it did not work I checked circuit and found no backup lights
David Moose
Old 04-22-2017, 10:22 PM   #7
I'd test for voltage at the backup alarm. Use two different grounding sources, like the - wire and then the bus frame. If you don't have voltage I'd agree that it's most likely a fuse. It could possibly be that a couple wires in a bundle got cut somehow, which could also cause a short and blow the fuse. I'd start by tracing the + back and looking it over as best you can. If you put a new fuse in and it pops again, it's knicked, which means you gotta find and repair it.
If you have voltage at the alarm using the frame as a ground, it's a bad ground wire.
Old 04-22-2017, 10:59 PM   #8
Robin97396's Avatar
My backup alarm was disconnected when I got this bus. I'm going to hook it back up again because it really annoys my neighbor, and for safety of course.
Robin
Nobody's Business
Old 04-23-2017, 09:08 AM   #9
be sure you are testing them with the engine running, on some of the transmissions, the backup lights are a pressure switch that when the trans enters reverse gear the lights come on...
Old 04-23-2017, 09:12 AM   #10
Great thought! Off all of us combined can figure out just about anything I would imagine.
