Old 03-03-2017, 11:22 PM   #1
turf's Avatar
bad electrical advise!
hey there. i know i post in this forum offering my electric advice, but people should take free internet advise at face value.
i wired in my new gauges today and when i started to reassemble the panel.... well..... Houston, we got a problem.
Turfmobile Build Thread
Old 03-04-2017, 12:12 AM   #2
I don't see smoke... So, what's the problem???
I need to replace the lexan gauge cluster panel on my boat (corners are chipped)... I've seen behind it, and I sure keep putting it off!
Old 03-04-2017, 12:28 AM   #3
turf's Avatar
the power wire got ran thru the steering wheel after i hooked both ends up
Old 03-04-2017, 07:04 AM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
BTDT. No problem, just cut the wire, strip about 3 inches and ,twist a couple times, cover with scotch tape.
Old 03-04-2017, 08:28 AM   #5
ahhhhh, i see now
was on iphone last night
that's an easy fix!
just leave enough slack to turn left twice, then back to center, and 2 turns right,,,, shouldn't be more than a couple feet.
Old 03-04-2017, 10:08 AM   #6
Hah, yeah that is a moment all right. There have been many times when I was feeling very pleased with how cleanly a project had came together, went to close it up, and then suddenly realized I had done something goofy - like soldering something in backwards or somehow managing to install a power button on the bottom of a case instead of the top. :eyeroll:
The real test is whether you are good enough to tear it apart and put it back together well enough that no one can tell you mucked it up just by looking.
lucasd is offline   Reply With Quote
Old 03-04-2017, 12:11 PM   #7
Scott Marcano's Avatar
Engine: Caterpillar 3116
Rated Cap: 78?
could have been worse, at least as said previous, there is no smoke!
Scott Marcano is offline   Reply With Quote
Old 03-04-2017, 06:13 PM   #8
That's what butt connectors & heat shrink tubing were made for!
It could always be worse....
My co-worker and I have nicknamed our boss, Poochy.
Cuz, he pooches everything he touches! EVERYTHING!
Old 03-21-2017, 02:20 PM   #9
Robin97396's Avatar
So... you gonna cut a slot through the steering wheel?
Robin
Nobody's Business
Old 03-21-2017, 03:11 PM   #10
Use a router. to dress the wheel up at the same time.
