Old 08-11-2018, 08:51 AM   #1
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Basic electrical setup questions
So most of the diagrams I'm finding are for people planning their all out electrical setup with solar and everything, not so many basic ones out there that I could find. I'm starting to wire mine up (got outlets hooked up and wired to a central spot so far) and I have a few queestions. I have a 12v background but never done something quite like this.
For right now I'm planning on having just my generator as a power supply for the bus. This is temporary while I'm working on the bus and will not be the only power source. A battery bank will also be added before I hit the road and leave the storage lot.
First question is about load centers / transfer switches. I will primarily be boondocking as much as possible, but will still probably have a 30amp shore power hookup. I have no clue what I'm looking at with these things. I bought a 6 space 100amp load center, but I don't think it's ideal because it doesn't have a main breaker, it's just a load center. Can anyone help me figure out what to buy?
If I am just running my generator. which is a champion inverter generator, I was planning on cutting off one end of the 30amp cable and wiring it straight to the load center so I just plug into the genny and I have power. I think I'm missing something though. This would be set up as a super basic electrical system just to have power in the bus and not have to use extension cords and move genny around.
Alternative - wire up a 2 battery bank for now until I can add the rest (was thinking a 6 battery bank)
If I go the route with 2 batteries, will I need to install the charge controller and inverter and everything right away as well? Long term electrical plan is Run the bus off my battery bank, use genny to top them off, and add solar down the line.
Thanks in advance for any help!
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 08-11-2018, 10:16 AM   #2
nanoplane's Avatar
Chassis: MVP
Engine: 8.3L Cummins Turbo
So get an inverter that includes a charger and transfer switch.. I have the AIMS 3000W pure sine wave inverter. It handles a 9000W Surge and includes a 100A (adjustable) charger and transfer switch. You just run shore power through a pair of breakers directly into the inverter, then the output of the inverter goes to your load center. The inverter can be set to either battery priority or Shore power priority and will switch automatically and will automatically charge the batteries when low.
The configuration runs in parallel to your solar setup as well and the Inverter and Charge controllers work happily together.
You don't need to install the solar and charge controllers right away... they can come later if you like.
For your generator, If it's a portable, you can just plug it into the shore power connection on your bus. If you want a permanent installation, you'll need to add in another transfer switch to select shore power or generator. Note, the AIMS inverters also include connections to auto-start your generator when the batteries get low.
Here's my electrical:
--Marcel
Build Thread
nanoplane is offline   Reply With Quote
Old 08-11-2018, 10:22 AM   #3
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Entirely my opinion... a main 110VAC breaker is not essential (like it is in a house). With a bus/RV, it is very easy to disconnect from shore power or turn off the generator - accomplishing the same thing (disconnect the power from the panel). Obviously this eliminates the primary purpose of any fuse/breaker which is to protect the wire. However; all shore power (that I've seen) and generators have a breaker to do that very thing. So, in my opinion, a main breaker is not required. An electrician will disagree.
You need a load center/breaker box that has enough "slots" to power the circuits you have planned and the circuit breakers to fill those slots. Typically those breakers are 15 amp, sometimes 20 amp. Remember that there are breakers that will handle two circuits (twin or dual CB's) so your 8 slot panel can handle up to 16 circuits.
What you said about a wire from the panel to your generator (or shore power) will work - for the simple system you have described. This can be dangerous when you an exposed/male plug AND an inverter hooked into the system that could be powering the panel (or anything else providing 110VAC). If no inverter, no worries.
With batteries, you need a way to charge them so generally yes, a battery charger/converter connected to your AC breaker panel. However; you might have a generator with a 12V charger (which is generally pretty weak and dumb) and that could be used instead. No, you do not need to install the solar components or inverter now. That said; having a design in mind now might save you some work and dollars later.
JD - Full timer out west
My Adventures & Build
Old 08-11-2018, 10:40 AM   #4
This is my setup as well, but I've got the Aims 2000w inverter. It's nice to have the inverter/charger/transfer switch all in one package. I got a dogbone (adapter) to connect the 20A generator outlet to the 30A shore power cord, which goes to the 30A outlet on the side of the bus, and that connects to the inverter for the pass-thru to the AC panel.
Old 08-11-2018, 10:55 AM   #5
Op, I take it you already have your genny? Is it electric start or manual pull start?
This is where you have to decide now for future.
If you have the genny what are the details?
Old 08-11-2018, 11:15 AM   #6
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
It's a pull start champion inverter genny. 2800/3100w with a 30amp hookup
Im possibly selling my SUV this weekend and picking up a cheap truck from a coworker and will have some extra money afterwards. I'm going to put most into savings, but now I'm thinking I should just go ahead and get an inverter charger now, wire in shore plug and then add 2 batteries at the same time so I don't have to rewire everything later.
I can mount the genny underneath, and then just get a cord to plug it into the shore plug on the outside, it won't be hardwired in. The shore plug goes through a 30 amp breaker box, then into the AIMS unit, and then that goes to my load center. Right?
EDIT -
I already bought a 100amp load center with 6 slots, and 15 / 20 amp breakers depending on the outlets on that line. I have some basic 15amp circuits and some 20amp gfci
https://www.lowes.com/pd/Square-D-12...Center/3134331
Details on bus - Propane stove/oven and propane tankless water heater, so don't have super heavy loads from any big electrical appliances. Will have a mini split AC
Old 08-11-2018, 12:05 PM   #7
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
I can't see the attachment and I would love to.
2martins is offline   Reply With Quote
Old 08-11-2018, 01:57 PM   #8
nanoplane's Avatar
Chassis: MVP
It's a PDF, you should be able to see it..
here's the URL: http://rivard.org/images/MagicsKoolBus/Bus-DC.pdf
--Marcel
Build Thread
Old 08-11-2018, 02:32 PM   #9
Ok here's the part I don't get. You have a pull start genny at present.
In future, you will be needing a different genny, an electric start type, if you are using grid power at some point. Why not do that now and be done with it. You frame it in now and wire for auto start and transfer switching.
Just trying to save you some hassle because it will be as you close in walls, floors etc. And you have to know it works before you bury stuff.
If you are ok manually plugging your panel in to shore and into genny separately that's cool but it will cost more and be more difficult to install what is proper for auto switching of power sources.
Like can you afford to loose food or air when you encounter a power outage on your travels. Build it for the future and for another owner. That is money in your pocket then.
Old 08-11-2018, 02:38 PM   #10
nanoplane's Avatar
Chassis: MVP
I know for me, a generator would just be there to charge the batteries if there's not enough sunlight to keep everything running... I'm looking at a portable generator for that task since then it lets me use it for alternative purposes and it means I can get a smaller / quieter generator since it doesn't really need to power everything AND charge at the same time.. well, I can live with that...
--Marcel
Build Thread
